Need help back firing and boging ?
I TOOK MY 70 CHEVVELL WITH A LS1 TO A FORD SHOP AND THEY JEST DID DO A GOOD JOB! BUT NEED HELP I SCANNED MY MOTOR AND THESE 4 DIFFRENT CODES CAME UP PO135 O2s HEATER CIRCUIT BANK 1 SENSOR & ALL THE WAY TO NUMBER 4, AND I ALSO GOT PO327 KNOCK SENSOR 1,2 CIRCUIT, LOW INPUT ?
I put the engine my self but i took to them to tune it and fix everything that was wrong with the motor but they could never get it right. I mest up and i took it there cause a friend told me about that place. Another qustion what the stock fuel psi
^^^How about some constructive criticism
Did you use a factory harness or something like a painless system?
Id start checking all of the connections. It does have knock sensors in the valley cover under the intake right? There should be a short harness coming out the back of the motor under the intake. Also how many o2 sensors are you using? If you are only using teh front ones the rears need to be turned off in the computer otherwise it will log a code.
If its bogging and backfiring something is probably wrong in the tune or the sensor wiring. You should really take it somewhere that knows the system, CMS could help you out for sure.
yeah i tolled him to take it too you ryne **** this car was running really strong from what i remember never had any issues till he took it to that shop i lost touch with this guy when i ran into him it was to late the svt guys ( stupid vehicle team )had did there damage. kool kid real new tho lsx tho
ya going to it take to cms, but seems it could be the knock sensors going bad still going to take it thow to have it checked out .....>>>. o and i picked that name cus thats the first thing that came to my mind and its my dogs name
