HOOSIER RECOMMENDS 315/35/17 on a 10"
i got this info right from hoosier's site page 15 of the tire catalog if someone can get the actual pic i don't know how since its a pdf
d.o.t. Drag radials
item tread tread approx. Approx. Recom. Measured section
number tire size pattern width dia. Circ. Rim rim width compounds
17310 p225/5or-15 e 8.5" 23.9" 75.2" 7-9" 7" 9.3"
17315 p275/50r-15 e 9.5" 25.7" 80.8" 8-10" 8.5" 10.8"
17316 p295/65r-15 e 10.0" 29.6" 93.0" 8-10" 8.5" 12.0"
17317 p275/60r-15 e 10.0" 28.0" 87.6" 8-10" 8" 11.3"
17318 p325/50r-15 e 11.75" 27.7" 87.2" 9-11" 10" 13.2"
17319 p315/60r-15 e 11.1" 29.7" 93.5" 9-11" 9.5" 12.8"
17320 p225/50r-16 e 8.8" 24.9" 78.3" 7-9" 7" 9.3"
17325 p255/50r-16 e 9.5" 26.3" 82.5" 8-10" 8" 10.5"
17330 p275/40r-17 e 9.8" 25.7" 81.0" 9-11" 10" 11.3"
17332 p315/35r-17 e 11.5" 25.6" 81.6" 9-11" 11" 12.6"
17335 p335/35r-17 e 12.0" 25.9" 81.4" 11-13" 12" 13.5"
17342 p648/30r-18 e 11.0" 26.0" 81.7" 11-12" 11" 11.7"
17345 p335/30r-18 e 12.2" 26.2" 82.2" 12-13" 12" 13.2"
From the 2009 Hoosier race Tire Spec catalog:
Item # 17332 Recommended rim: 9-11"
Measured rim: 11"
So they got that tread size on a 11" rim, anything smaller than that will give you less contact area.
Measured rim: 11"
Yes, there are a select few 315 tires you can get away with on a 9.5" stock wheel. But thats just b/c they run skinny compared to most other 315 tires. This is a topic thats been beat to death way too many times & always ends with some smartass tryin to mouth off to mods.
Personally I would never run any 315 tire on a stock wheel, it's just not smart period. If you need a tire that big either upgrade wheels or run a drag rim with a good sticky tire.
I don't think they would put that info on their site if it could lead to a lawsuit or someone getting hurt
P.s most of the 315's are too wide but some aren't therefore you can't say its unsafe, you got to check with each tire manufacturer. Nitto's still say a 10.5" wheel is minimum but hoosier says you can put their tire on a 9"-11" wheel so i think they would know better
I think a company like Hoosier knows better than some dipshit like you if that is unsafe, unless you're in a tire R&D than you're opinion is just an opinion like mine and others.
Dude your not very bright. Did you even read my post?? I said there are "SOME" that will fit. I never said the brand you mentioned wouldn't work. Reading comp. owns you, so I wouldn't be knockin someone like myself who has been around these cars long enough to know what will & will not work.
My opinion if FACT. And I get my facts from personal experience & watching others experiences on this board. For you to knock the mods for not wanting unsafe information posted shows your level of intelligence. I don't see why you have sand in your vagina anyway, you followed forum rules & posted the manufacture's information showing rim size fitments.
So exactly what is your point?? Tryin to prove something most people on this forum either already know or can simply find in a search in this section?? If you don't like how the forums are run then by all means
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
My opinion if FACT. And I get my facts from personal experience & watching others experiences on this board. :
i don't care about you talking ****,this is not a dick measuring contest all i'm saying is that you and the mods have no proof that putting ALL 315's on a 9" rim is unsafe and since hoosier states that putting THEIR 315 on a 9''-11'' rim is recommended(SAFE) i think they have more experience than you and the mods atleast in the tire department
LOL, so now your a tire guru, give me a ****** break dude & stop spreading bad information before you take a long or neverending vacation from here.
You go run any brand 315 you want & be a ****** dumbass, the rest of us who care about our saftey & others on the road with us will continue to run the proper size tires on our cars.
Unless your gonna actually contribute some good to this forum why don't you just ****** leave with your infinite tire knowledge. (which is very limited to almost none)
Man it's pointless with you. We already established that the brand of tire you are talkin about specifically say from the manufacturer that it can be used on a stock width rim. So stop being a ****** idiot.
Then you say the people on this site have no proof that ALL 315 tires won't fit. That was never stated. What was stated was that certain one can but they are very limited. NO not ALL 315's will fit a stock width rim, thats a FACT weather your pea brain wants to believe it or not. Like I said, go ahead & go buy whatever brand you want & mount it up then.
I have been around this site & seen first hand that ALL 315's will NOT fit a stock rim without risking safety. And I will not sit by quietly while you make uneducated statements like we have no proof. Why don't you go look at every company who produces a 315 & then come back with all this info & paste it so we can prove not ALL 315 are made to fit a stock width rim. I bet you find 95% of them suggest nothing smaller than a 10-10.5" wheel.
Don't try to talk about technical facts to people that know more than you about said subject. I also suggest you learn to comphrend what you read before you post cause your getting owned by facts.
did you not read the STICKY on top of this forum you're the one owned by Facts(not opinions)
here's what the sticky said
315/35R17's DO NOT FIT 9" or 9.5" WHEELS!!!
This will not be discussed. I will not tolerate that kind of post. If I see if posted it will be deleted no questions asked.
Read the tire manufacturers recommendations.
If you are foolish enough to try it fine . . .
If you find a tire shop ignorant enough to install them fine . . .
But encouraging others to recklessly experiment, NO. Do not PM me in regards to this, I will not reply. If you don't like my stance then complain to Brains or Nineball.
Sincerely,
The Tire ****
so i've read the tire manufacturers recommendations and it seems that 99% of them agree with that except for Hoosier , SO THEREFORE STATEMENTS THAT SAY YOU CAN'T PUT 315'S ON A 9" RIM OR THAT IS UNSAFE ARE B.S MOST YOU CAN'T BUT NOT ALL
and i never once said i know more about tires than you but you keep saying that you know more about the tires than me, great i don't give a **** and you got 3400 posts and been a member since 2005 i can care less about that too so you can
Sincerely,
The Tire ****
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
