Nitto NT05
Old Aug 21, 2009 | 02:57 AM
  #101
cookba's Avatar
Any updates on new tire sizes for the 18" and 19" guys?
Old Aug 21, 2009 | 11:20 AM
  #102
Discount Tire's Avatar
Still patiently waiting.
Old Aug 24, 2009 | 12:54 AM
  #103
z34_nut's Avatar
please produce a 315/35/17 NT555R2!!
I really want to stop running 275's for the advantage of running the R2's... Also, I'm not a big fan of these new tread patterns on the NT05's...
Might be good with a vette set up (considering the 19/20" offerings), but doesn't do much for me considering I want to continue running 17's. I would like to use 315's all the way around for track use.
Old Aug 24, 2009 | 10:10 AM
  #104
You should look into the Nitto NT01. This is a great competition tire for track use and is produced in the 315/35-17 size.
Old Sep 6, 2009 | 06:09 AM
  #105
cookba's Avatar
So what 18" sizes are Nitto possibly coming out with?
Old Sep 10, 2009 | 01:01 PM
  #106
NavdeepWS6's Avatar
i just bought a set of these
275/35/18 and 295/35/18 and i cant wait to see what they look like on the trans am and the grip they offer they should arrive tomorrow
Old Sep 23, 2009 | 06:39 PM
  #107
Content added to the OP.
Old Sep 25, 2009 | 01:59 PM
  #108
Blackened2k's Avatar
I just want to say anyone debating on ordering a set.. GET THEM!
These tires are FANTASTIC. MY buddy just got em on all 4 corners of his SS and its probably the most grip his car has ever had. So far they've been wearing really well, but I imagine some more spirited driving will start to wear em down. It's probably as close as you can get to drag radial like grip without dying in the rain.
To top it off they look great on the car.
Old Sep 29, 2009 | 09:56 PM
  #109
Dark Shadow's Avatar
please make 315/30/18
Old Sep 29, 2009 | 10:08 PM
  #110
tripps's Avatar
These tires look pretty good, I'll probably buy a set here soon.
Old Sep 29, 2009 | 10:50 PM
  #111
SSpeedracer's Avatar
how do the NT-05's stack up to the Kumo Ecsta XS KU36?
For 315/35R17's, the Kumo is slightly wider with a slightly larger diameter and thread depth. They both have those big *** water drainage valleys. The Ecsta is a few bucks less.
Old Oct 4, 2009 | 09:09 PM
  #112
Greed4Speed's Avatar
How do the Nitto NT05s stack up to the Toyo R1R's?
Old Dec 2, 2009 | 01:14 PM
  #113
JimMueller's Avatar
Taking some time off from autox next year, so I'm considering taking the 315/35/17 Hoosier A6's off my 17x11's and replacing them with the NT-05's for street use. I'm not terribly keen on the huge water trenches in the tread pattern, though. If I get them, I'll stack them next to the Hoosiers for comparison.
Old Feb 1, 2010 | 10:02 PM
  #114
HoLLo's Avatar
I'm changing my vote to a 315/35/18 now that I have 18" wheels! Cmon give us a 315/18!
Old Feb 2, 2010 | 07:27 PM
  #115
Tom565's Avatar
This picture is from page 2, post #36. Which tire hooks the best for street use in this line-up?
Old Feb 16, 2010 | 04:22 PM
  #116
Old Feb 17, 2010 | 11:31 PM
  #117
555's always (ones furthest to right)
I am disappointed with the NTO5 315/35 and wish that I had stuck with 555R's, RII's or tried NT01's or another manufacturer altogether.
I got the NT05 expecting a trade off. Improve wet traction of NT05 at the expense of dry traction of the 555. The added NT05 millage was a plus.
However, NT05 is only mildly better wet than 555's. Almost not noticeable.
On the other hand, the 555's hook MUCH better than NT05's dry. I gained hardly any wet traction and loss too much dry..... bummer.
The only saving grace is advertised mileage. But mileage rating is mostly advertiser gimmick and less scientific. ie Nitto 100 wear rating is NOT equivalent to Bridgestone wear rating. Use wear rating to compare tires form the same manufacture NOT between manufacturer.
Nitto rates the 555R, 555R2, and NT01 5 out 5 for dry traction. They give the NT05 4.5 out of 5. NT05 should be more like 3.5 or 4 out of 5 max.
They rate the 555R and 555R2 2 out 5 wet traction while the NT05 is 3.5 out of 5. Nope, NT05 should be 2.5 at best.
Miles driven to come to this conclusion: 10K on NT05, 6K on 555R2, 45K on 555R1. Roadcourse, highway, street wet and dry.
Look at the NT05 tread pattern, it doesn't make sense. Two huge channels that remove at least 14% surface area and a "slick" section down the middle where water is going to cause problems. huh?
Old Feb 18, 2010 | 08:55 AM
  #118
Thank you for your thoughts.
It's important to remember that the NT05 Max performance is not an R compound competition tire like the NT01, NT555R Drag Radial, and NT555RII Road Race so it will not have the same dry grip. The NT05 is a max performance summer tire with reinforced internal construction for better stability at higher speeds and superior dry grip under hard cornering. This model should be compared to other models like the Z1 Star Spec, Kumho XS, and Azenis RT615.
The three tire models pictured all run in different classes so it depends on what you are looking for. We can certainly help you pick the best model for your needs, just tell us a little more information. How many miles are you driving per year? I assume you're after a tire for summer use only? What tire model are you currently driving on and what were your likes and dislikes? Will you be doing any racing? If yes, what type (IE road race, drag strip). What do you want your next set of tires to do for you?
Old Feb 18, 2010 | 03:09 PM
  #119
EchoMirage's Avatar
has anyone else run these in the rain? im seriously thinking about these, hopefully in 275/17 on a 3rd gen. without going into too much detail, call it extremely hard driving on street, with road conditions from good to poor, in dry and absolutely wet conditions.
i know their dry handling will be pretty good, but i have to know for a fact the best evaluation of their wet performance. has anyone done a totally wet track day, or really hard street driving in the rain?
Old Feb 19, 2010 | 10:49 AM
  #120
rsoetidjo's Avatar
Hey guys. I have 500+hp with 4:11 rearend and M6 on my camaro. I only drive my car about 2-3 times a month. And try not to drive in the rain. I had Bfg before and I love them (except on the rain). Now I have Nitto NT555 DRAG and they're sucks. Size 315/35/17. And now the time to get a new set for the rear. What do you guys prefer to use on the street? The BFG DRG radial, Nitto NT05 DRG radial (not the NT555 DRAG )? I know alot of people prefer go with MICKEY THOMPSON DRG radial . But they're cost money.
