What pressure to run ET Streets at for best life?
Old 05-18-2009 | 04:17 PM
LS1Formulation's Avatar
Default What pressure to run ET Streets at for best life?
I had Nittos previously and they got the best tread life running about 27PSI. Just got a pair of ET Street radials today and I'm wondering what sort of pressure I should be running to get a decent amount of street life out of them
Old 05-19-2009 | 11:33 AM
Anyone?
Old 05-19-2009 | 11:44 AM
blu byu EH's Avatar
I have mine at 30 and when I race I drop them to to 18~
Old 05-19-2009 | 10:01 PM
Are these way more squirrelly than Nittos? Because man... I get on it a bit in these and I am all over the place. Not spinning, I just can feel the back end of my car move around a bit. They feel like bias plies!
Old 05-19-2009 | 10:05 PM
MIGHTYMOUSE's Avatar
mine are always around 20
Old 05-20-2009 | 01:37 PM
mattl31's Avatar
i keep mine at 20 psi. only way i get full tread pattern contact
Old 05-22-2009 | 12:28 PM
mojolamar's Avatar
Keep mine at 22 and drop them to 10-12 when racing
Old 05-24-2009 | 12:12 AM
nitrobusa's Avatar
I keep mine at 20 and drop to 13-14 when racing
Old 05-24-2009 | 01:58 AM
ZMONSTER!'s Avatar
Ive had mine for 6 months at 20-35 PSI, went as low as 18 once. I still have much life left.
I think the amount of life youll get is related more to how much racing you do more than tire pressure. If you use the tires like they are meant to be used they wont last long!
Old 05-24-2009 | 01:25 PM
cody161's Avatar
With the et streets (not the drag radial) my car moved around quite a bit a couple times!! It was just something you had to get used to and learn how to keep it from doing it.
Old 05-24-2009 | 05:43 PM
SS SLP2's Avatar
running et streets (not the drag radial ) against radial on the front can get to be a great problem. unless you are running a heck of alot of HP the MT drag radial will hold most any street car if good suspenion.
as to milage at 22 psi on street I maaaayyyy get 12-1500 miles from them
my .02' Johnny
