Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#402
I did not know the factory size for sure but thought that the 17 x 10 with the offest of 36 might be too much for the front. I'll probably try to get 17 x 9.5 with around a 48mm offset instead which should put the wheels about a .5" out farther and look better(definitely not going for the ricer look). Thanks I'll be sure to post when the care gets its new shoes. Thanks
#406
OK I just want to triple check before I click order! *still need to flip a coin on what rims
17x9 ZR1 rims knock offs
17x9 SS rim knocks offs
I was thinking 275/40/R17 all around is there a tire that is 285 or 295 that fits on a 9" wide rim? Or should I just do 275 all around? I was thinking of running ZRIs again for daily from me enjoying mine before and trying to keep costs low.
Also if somthing I said is stupid feel free to warn me!
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
#409
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
Most after market ZR'1 style wheels are 9.5" wide . . . 275/40ZR17 is the best recommended tire, but a 285 would fit.
#411
Originally Posted by Xsta Z 28
ZR'1 and SS "knock offs" are the same wheel . . .
Thanks for the prompt reply going to get me some new shoes now
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#412
Just to pe absolutely positive..
z06 replica wheels (18x9.5 with +56mm offset) with 275/35R18 's will fit like a charm? or will it need a spacer? if so where can i nab one and what size?
#413
#414
OK, I searched this thread and didn't find it so here goes:
17x9 American Racing Rebels on a Camaro. I believe the backspacing is 21mm, which is significantly less than the 35-45mm range listed here.
Will they fit with a fender roll? Will they fit lowered an inch or so?
#415
#416
Xsta,
I've read almost all 21 pages (probably 18+) and I'm sure I'm Ok but I wanted one more head-check before pulling the trigger. I have an 02 Z28 and I want to purchase a set of replica C6 Z06 Chrome wheels. the size I want to use on all 4 corners is 18 x 9.5. Offset is +50mm. I plan to use P275/35 18 tires all around. I figure there should be no modifications needed to my car. It is not lowered. Am I in good shape? Is the P275 the ideal width tire or is a P265 better?
Thanks!
Thanks!
#417
Originally Posted by Mike02Z
Xsta,
Thanks!
Thanks!
#418
I got some new wheels
17 x 9.5 zr1 wheels for the front 56mm...I am going to use---275/40/17's
17 x 11 zr1 wheels for the rear 56mm...I dont know what size to go with. I want them to be bigger than the front for performance and the "cool stance" but I dont want to hammer or modify anything. I am having trouble understanding the size guide. can someone please guide me...285,295,305,315 etc. etc.
thanks alot and sorry if I sound dumb. I read the whole thread and did research..
Jay
Jay
