Old 04-26-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
Old 04-28-2006, 08:50 PM
  #501
kyle91z28's Avatar
well he has rear drum brakes because it was a 3.4 V6 before hand..
kyle91z28 is offline
Old 04-29-2006, 06:57 PM
  #502
mtrudel1978's Avatar
Default 275/45/20
I was wondering if 8.5/20 Rims with a +38mm offset would fit. The tires that are going to be on them is 275/45/20's. Is it possible? I'm already assuming that the tires won't fit on the front but the back i think they will. Can someone let me know for sure please if these will fit without doing any mods.
mtrudel1978 is offline
Old 04-29-2006, 10:02 PM
  #503
Xsta Z 28's Avatar
Originally Posted by v8hunter
I have some 18x9.5 c5 wheels that I am going to get a set of 1/2" spacers for the rear of my t/a. What length of ARP studs will I need? I have seen 2.5" & 3.25". Also the Baer spacers are the only (non cast iron) ones I have found...are they alright? If the Baers are not any good will you please direct me to a specific place to get some better ones.
Thanks in advance
Sorry I have no idea . . .
Xsta Z 28 is offline
Old 04-29-2006, 10:03 PM
  #504
Xsta Z 28's Avatar
A 45 series tire and a 20 inch wheel! . . . That would be nearly a 30" diameter tire . . .
Old 04-30-2006, 07:41 AM
  #505
Thanks anyways! I found out that 275/35/20 fit on the back and 235/35/20 fit on the front. I'll post a picture when i get them on my car. I appreciate the reply and hope you have a good summer!
Old 05-01-2006, 11:16 AM
  #506
Xsta Z 28's Avatar
Why are you using such a tall tire?????
Old 05-01-2006, 01:07 PM
  #507
blind527's Avatar
I found out a Nitto 325/50/15 will fit on a 15x10 Weld Prostar, so I will be going with that.
Anyone know how heavy the 325's are? I was thinking about getting the 295 BFG's, but they are almost 30" tall. I would get a 275-295 on the 15x10's, but they don't have any good sidwall heights. The 325 size seems best. I also thought about getting a 15x8 and putting a 275 on, but I want a little wider than that.
blind527 is offline
Old 05-03-2006, 06:01 PM
  #508
DarkLordFtT's Avatar
anyone know what size spacer or adapter I would need to make this combo work....
I just got an '81 vette (still have the TA) and I want to fit a set of trans am GTA wheels I have on it.
Vette Wheel--Short spoke spider,
steel rim--15x8
Wheel Offset= -0.50"
Note*
50 inch =12.7mm.
GTA wheels:
16x8
rear wheels have a 16MM offset
fronts have 0mm offset
(I'm going to place the 0mm (deeper ones) in the back. The problem I'm having is the huge brake cailpers are hitting the wheel.
so spacers come in 1/2" increments. The 0mm (front gta's) only need a 1/2 " spacer to make them -.50
and the 16mm (rear gta's) need a 1 1/2" spacer because 16mm = .62992125 inches
and .62992125 + .50 = 1.13" therefore 1.5" (1 1/2") spacer... right???
and longer studs to mount them on.
*Update... I found a guy on ebay who can custom make a set for me...
DL
DarkLordFtT is offline
Old 05-08-2006, 07:32 PM
  #509
stevensLS1's Avatar
will a 325-50/60-15 fit under a trans am on sportlines with the fender rolled?
stevensLS1 is offline
Old 05-09-2006, 09:55 PM
  #510
Restricted User
NBM2001z28's Avatar
What 15's can you run and what tire on a GTO with the rear fenders rolled. Looking for Skinnys up front and 15X10 or 15X8 in back. SHOOT ME A PM PLLLLLEASE
NBM2001z28 is offline
Old 05-10-2006, 08:34 AM
  #511
raejenls1's Avatar
i'm looking to buy a set of 4 smoothie 2's at 17x10 with a 38 offset... i'm planning to put a set of goodyear f1 d3's at 275x40x17on them... will they fit without rubbing in front or back with he 38 off set?
2000 t/a
thanks
raejenls1 is offline
Old 05-11-2006, 10:42 AM
  #512
stangkiller2005's Avatar
will a 19x10 c6 wheel fit on the rear of a 2000 ls1??? please let me kno... im about to purchase i just need to kno if they fit first... i got a killer deal on them.
stangkiller2005 is offline
Old 05-22-2006, 06:14 PM
  #513
junkz28's Avatar
i know this has to be posted some where, i tried searching and couldn't find it and couldn't find it in this thread.
I know it says that the correct backspacing is 4.75 for the ls1's, but will a 15x8 with 4.5" backspacing fit? This is probably a dumb question, i just don't know the answer
junkz28 is offline
Old 05-23-2006, 11:46 AM
  #514
Xsta Z 28's Avatar
As far as I know not with out spacers/ adapters. They have a very big offset.
Old 05-24-2006, 01:52 AM
  #515
Avengeance's Avatar
First of all, thanks for this post and offering your help to all of us.
I have a set of stock 10 spoke SS wheels from my 2002 35th Anniversary car.. they are the ones that have the black centers with the polished face. They are physically the same size/offset as every other stock OEM 10 spoke.
Im sending them out to be widened to 11" to retain the stock look and have a wider tire.... 315s. When it comes to my car the one thing I dont understand fully is the whole offset thing.. and since Im physically altering my wheels I have even more confusion.
Im trying to figure out what size spacers I should use to make these widened wheels work with 315 rubber.. I dont mind massaging the wells if need be, or rolling the lip if I have to. I already have aftermarket APHR and LCAs... and Im ready to cut the bump stops off if I have to.
I need help with the spacer size.. what am I going to need? Am I going to need longer studs?
Thanks.
Avengeance is offline
Old 05-28-2006, 08:09 AM
  #516
gun4hire's Avatar
Thanks.
In your case, I would wait until you have the wheels back. Mount up tires, put car at ride height on jack stands and stick the wheels in position to "mock up" where you want the wheel...then measure. THAT will give you absolutely the best results.
...and yes, you will need longer studs most likely.
gun4hire is offline
Old 05-30-2006, 10:19 AM
  #517
Xsta Z 28's Avatar
Exclamation
Very good advice.
But here's how it works by math: Ultimately since you are adding width to an existing wheel, and most likely all of the new width is going to the back side of the wheel. With all the new width on the back side, the offset of the wheel (for a F-Car) would increase by 50% of the added width.
So, a stock 9" 56mm offset wheel, widen 2" . . . 56mm + (50% of 2") = 81.4 mm
To bring the wheel back to the right offset a spacer is needed. The ideal offset for 11" wheels is between 46 mm and 50 mm, so . . 81.4 mm - 50 mm = 31.4 mm or 1.23"
A nice hub and wheel centric adapter will do the trick. Width is going to be between 1" to 1 1/4" . . . (mathmatically)
Old 06-01-2006, 12:25 AM
  #518
FUroundeye's Avatar
I'm pretty sure I know the answer to this, but just double-checking: an 18x9.5 wheel w/ a 65mm offset wouldn't fit on the front w/out a spacer, right? TIA
FUroundeye is offline
Old 06-01-2006, 10:47 AM
  #519
F-117HWK's Avatar
I dont know if this has been answered, so let me know if it has and where to find it but I have a '99 T/A with the stock 16" wheels and 245 rubber and am looking to purchase the Torq Thrust II's 17x9 for the front and 17x11 for the back with plans to put 275's on the front and 315's out back...what fit modifications will need to be done to ensure no rubbing/hitting problems? Any info will be greatly appreciated, Thanks.
Also I read that tire height differences will disable ABS on f-body's...Will the proposed setup make this happen? (Im planning on using the Eagle F1 GS-D3's)
F-117HWK is offline
Old 06-01-2006, 11:56 AM
  #520
350 HRSS's Avatar
Also I read that tire height differences will disable ABS on f-body's...Will the proposed setup make this happen? (Im planning on using the Eagle F1 DS-G3's)
You won't have any problems w/ the 17x9 TT2's up front. I have the same setup on my 95Z. For the rear, I used 17x11 TT2's w/ 315's as well. We had to bang the fender in about 1/4". It sounded worse than it looked. But it took care of the problem!
What I have seen from all these threads is that EVERY F-body is different. Some won't have to have the fenders banged in at ALL. And some have to have up to an inch banged in. Just test fit them and see You will be HAPPY with the results, I can promise you that
350 HRSS is offline
Quick Reply: Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
