Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#681
Originally Posted by mindreaper
Thanks for your help, I really appreciate! I don't know much when it comes to tires and I was a bit lost...
If you don't mind me asking one more question: what tire width/ tire height would be OK at the rear without mods? I've burned all my budget on the wheels, springs and Koni's, so chassis mods could wait until I wear out those tires.
#682
Originally Posted by EchoMirage
hate to ask a question thats probably been answered, but i cant look through 23 pages right now and search isnt working......i bought a set of Trans Am 16s, non-WS6 to put road race slicks on. whats the widest i can safely mount on my 02 TA WS6? im looking for Kuhmo V710s, but i dont think they come in the size i need. any help would be great.....autoxing starts soon.
255/50ZR16
#683
Originally Posted by XLR8TOR
Fix the search button dammit.
Looking to get these...
https://host279.ipowerweb.com/~tomzw...cb88bfe0a6d1cc
or these
What tires can I put on a T/A 'vert with no BFH and no rubbing?
or these
The 18 x 9.5, run 275/35ZR18
The 18 x 10.5, run 295/35ZR18
#684
To use 345*30*18 BFG on mine of C5 I want to buy wheels 18*12 CCW with offset + 74mm. On car LPE mini tub kit is established. It will be good to work this size of wheel?
Whether there will be the: wheels will rub the upper control arm when the suspension is unloaded, it may also rub on the end of the rear leaf spring depending on how low the car is?
#686
You are asking questions beyond my experience, sorry I cannot help.
#687
John at CCW will get it all correct to order the right wheels
Can't give you any help on the 17" wheels, but OEM 18 x 9.5 Magnesium wheels have a +65mm offset to keep the wheel/tire inside the wheelwell for Euro standards and they work fine with stock brakes and a 295/35/18 tire on the rear, 275/35/18 in front, have them on our 2000 coupe.
#688
You speak, that wheel concerns the upper lever(arm). It can better($better) make wheels with smaller offset, for example 70 or 72 mms.? That it was possible to use wheels not only for dragracing, but also for driving for each day? Or then tires 345*30*18 will concern already wing of the car?
#689
Bolt pattern??? 5 x 120.7mm, 18 x 9.5 w/46 offset. Will that fit an 02 T/A proper? I know its only .05mm off, but is there a safe range fitmit around the 5 x 120.65mm that can be used as a guide?
#690
#691
Hey guys im interested in buying some custom rims soon I was thinking 18x9.5 or 9 in the front and 18x10.5 or 10 in the back. Can I run the 10.5's in the back and a 295 or 305 with out doing the bfh or the wheel sticking out past the lip. I want the front and rear rims to look even with the body and not the rear noticeably sticking out farther. So if the 10.5 in the back would be good what off set should I run? Thanks cause im interesting in buying rims really soon and I want to make sure it all turns out how I want it. I know a guy with a lt1 and 315's and he had no prob with rubbing but his rear rims did stick out a little farther then I like. I might just get the 10 and 295's but I still dont know the best offset for what I want.
#693
SpdFrk1990 I just bought the z06 18x10.5's with a 53mm offset and wrapped with 295 tire, i'm hoping for the same look that you want and I have a NBM ss, If i get a chance to mount them this weekend i'll do so if not i'll have to do it next weekend and i'll post some pics.
#694
#695
I've mounted 17" TTMs on my 1999 Z28. The rears are 10.5" wide (offset 44) with 285/40/17 Kumho Ecsta Spt tires. There's not that much clearance between the tire and the bump stop (you can put your finger in between but not much more). Do you think it's gonna be OK driving like this or do I need to modify something?
Also: next I'm planning to install Strano springs (1.3" drop) and Koni SA's. Will there be more clearance problems? Will I need an adjustable PHB?
#696
Once the car is lowered the wheel/tire should be farther away from the BS. An adjustable panhard is always recommended with any lowering, so that the rear axle can be re-centered.
#698
Hey Guys, I am unhappy with the factory tires on the stock 16 x 8 chrome wheels so Iwas thinkin of running 245/45/16's for tires. I think this will improve handling by going with the lower profile sidewall but I was also wondering...
- The overall diameter of the wheel/tire will change from 25.65 to 24.68. Will this lower the car a full inch? I really dont want the car any lower than it is...
-Will this change my 3.73 gear ratio closer to a 4.10 with the higher revolutions per minute? Will that reduce or improve gas mileage?
Thanks,
Lane
Thanks,
Lane
#699
spdfreak
I mounted the tires to the rims
275/35/18 on 18x9.5 rim
295/35/18 on 18x10.5 rim
http://picasaweb.google.com/mario.ur...WheelsAndKDW2S
(tires look weird due to eneven ground)
Waiting to paint calipers before putting thm on the car.
#700
spdfreak
Looks good man.
