325/50/15 et street radials?
id like to try to run these and see how they compare to my 275/50/15s. i just dont know how well they are gonna fit. what did you guys have to do to run them with no rubbing? i will be driving them on the street too. or would a 315/60/15 be better?
Location: Your girl's back door giving her the long stroke while you're at work
You'll have to roll the lips on the quarters, beat the hell out of the inner quarter and probably have to cut off the bump stops
I just went thru alot of the research when I was choosing for my car....the 325s are 28" tires so they will be taller then the tires you are running now plus the obvious width difference ...315s are 30s which I think will take alot more work and I haven't heard of anyone on here using them on a fbody....I know I ended up getting 275/60/15s which are 28s but narrower...I still plan on running 325s down the line but I got a great deal on these so ill go with them for now
