Tire sizes for best handling?
What's up guys. I did a search for this but found a bunch of different stuff so I'm still unsure. For best handling, is it better to use skinnier tires up front than in the rear?
I'm currently running 275/40/17s on all four corners but I see a lot of people running skinnier up front. I'm getting new wheels soon (chrome C6 5-spokes
) and just want to get the best tire combo I can since I'll be getting those too. Thanks in advance
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Tire quality will help you more than tire size. A 275/315 setup with crap tires will be worse than 275's all around with good tires. Technically these cars are set for equal tire size front and rear. To optimize a 275/315 setup you would need to make raer spring/shock adjustments.
LS1Tech Platinum Sponsor
I agree. If car is stock stay sith 275/40R17 on all 4 corners. Putting a wider tire in the back without making suspension changes will make the car understeer (push) in the corners. Put a set of Kumho XS which have a ton of grip, but wear quickly.
Hope that helps.
Mark.
So the general consensus is that I should go with the same size on all 4 corners since my suspension is stock? The car is an 02 Firehawk with factory springs/shocks so I don't know if that's technically considered "stock" suspension.
If the above ^^ is correct, can anyone recommend a nice grippy set of street tires that won't kill my wallet? I'm talking something above Super Steel's but below Eagle F1's.. lol. Car is only driven in the summer, and never in the rain. Again thanks in advance and thanks for the input so far
Many of the track guys run 17x11 at all 4 corners with 17/35/315s. Definitely a little extreme for a street car and will require some modifications to fit good.
If you are really interested in handling search around the suspension section while you are at it, you can dramatically improve handling/stability/feel/balance with simple mods like good shocks (konis).
Its "stock" as long as its factory. What they are referring to is altering the balance of the suspension (stiffness for example front to rear, like running an overly big rear swaybar will induce oversteer).
Nitto Nt05s, stock size (17/40/275) all around. Under $200 a pop, much cheaper than the goodyears and much much more grippy.
Most definitely, even more so if you have decarbon shocks(orange/black) - those might as well be paper weights. Definitely my favorite, and most noticeable suspension mod.
The wider the better, but as others have noted wider rears will make understeer more pronounced. Can't he get the car alligned to were this isn't as much of a noticeable problem?
Personally for a good street tire that will perform good on the track I'd say a NTO5 for the rear and a 555RII up front (not the DR's but the auto x and road course tires). Go with a 305 or 315/35 width rear and a 275/40 up front. The koni shock and strano spring upgrade is pricey but it will make your car handle like a dream. Bilsteins are about the next best thing behind konis.
Why would you want to mismatch tires? You will have more grip out of the RII's than the NT-05. Trying to balance the car that way (if you are rying to do so by running a higher grip tire in the front) seems like a bandaid. 275's all around with a NT-555RII, NT-01, or similar should provide a better return.
what would you guys say about something like my current setup?
I want to say maybe later down the road I'll run "brand name" springs....but i have to tell you. I am happy with this setup.....the fronts are cut about 1/3 of a full coil. And the rears from a 93 with more mileage...also drop the car plenty out back.
I'm very happy with the Koni's.
And im running Eagle F1's.
I would like to run 10 or 10.5 inch width wheels up front soon.
As well as 11 inch or 11.5 inch in the back....I know some mods will have to be done to fit.
I've got 32mm up front and want to do the 22mm soon as well out back.
I will likely go for hollow bars.(35mm frnt later also).
The car handles very tight. I could almost say it reminds me of a go kart at times....probably due to the poly up front. I want to dial it in some more.
What arrangement would u go with assumming 35/22 bars...? and the widths mentioned for wheels?
