Will these CCW 18x10's work on the front of my Transam?
Did some searching and found a few answers as to they will and they wont but that was a while back so I know prob beating a dead topic. Came across a set of 18x10's and 18x12's cheap. Here is the specs the seller gave to me.
CCW Classics 18x12 & 18x10 staggered
(9 inch backspacing) & (7.5 inch backspacing)
5x120.65 AKA 5x4.75
I know I will prob need a spacer. I also run pro kit eibachs on the front as well. I know the rears will fit as I have ran a 10.5 before and did some banging on the inside and took the bump stops off and ran a spacer. Will the front clear and what kind of tire do you guys suggest? I saw someone was running 295 but dont remember what size sidewall.
Thanks and hope to get some answers from you guys!
Chris
5x120.65 AKA 5x4.75
Chris
Well I will have to look into seeing what you have to do to run those rears without doing major modifcations.
