17x11 zr1's all around
Old 03-13-2012, 01:46 AM
The Batman's Avatar
Default 17x11 zr1's all around
I have been searching all over the Internet lately trying to find pictures of a firebird/trans am (preferably lt1) with 17x11 DD Zr1's on all four corners. I have been itching to buy a set from oewheels as an autox/road racing setup. My plans are to run nitto NT01 or NT05's 315/35/17 on all four corners. But for the life of me, i cannot seem to find any pics (of decent quality) with this rim setup. So I have decided to ask you all, thank you.
Old 03-13-2012, 05:56 PM
Captain Double Post
BOBS99SS's Avatar
Pics are out there, why don't you google what your looking for then go to images. You will find your pic
Old 03-13-2012, 06:08 PM
solidsnakecsm101's Avatar
https://ls1tech.com/forums/wheels-ti...-around-3.html
There you go
Old 03-13-2012, 10:51 PM
Ballzee's Avatar
Looks horrible on 3rd gens.
Old 03-14-2012, 12:51 AM
The Batman's Avatar
I have tried google searches like crazy, I've already found the thread that was posted as well. That thread isn't very close to what I'm looking for really. But thank you. I'm still trying to find the DD zr1's 17x11 all around on a Pontiac. I know they exist somewhere
Old 03-14-2012, 01:22 AM
Blk98Vert's Avatar
What you are looking for does not exist. I have yet to see or hear of anyone rinning the DD 17x11s on any LT1
Old 03-14-2012, 10:06 AM
RAMPANT's Avatar
Not sure why an LT1 would be any different as the 4 gens all have the same openings.
an option to consider would be TTMs, I use 10.5 x 17s on all 4 corners for my track/autocross set up. The down side is you can not fit a bigger brake in there. I would love to have CTS V brakes, but they will not fit. I even checked the other brake solutions and they do not go. I am prety sure the Vette track bracket solutions will though.
Anyway, they look pretty tough on the car, though I prefer my staggered on the street.
Autocrossing on them.
Mine do not really stick out, but I do run -2.0 degrees of chamber, which helps to keep the top tucked in.
I only have one mod on the front end for clearnce. I added 4 screws through the plastic inner fnders to keep them pulled back to the metal as there was some rubbing at full lock. Nothing major though. No spacers, nothing.
Old 03-14-2012, 11:17 PM
The Batman's Avatar
Thats awesome! I have read about guys who have done this on frrax, but it seems that nobody ever posts pictures there
Old 03-15-2012, 07:30 PM
The Batman's Avatar
I was given these pics from another website. .313" spacer on the front with a smaller spacer on the rear. Looks like i need to sell my current wheel setup. [IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 03-15-2012, 08:03 PM
bad_408_vert's Avatar
Interesting, I was wondering how street drive ability or any cornering be with wheels/tires that wide on the front.
Old 03-15-2012, 09:18 PM
RAMPANT's Avatar
I only street drove them a couple times. The tires are 315 Toyo R888s and they are very stiff. As can be expected, they grab the crowned roads and grooves. Not really much worse than my 275 Kuhmo V710s did.
Keep both hands on the wheel if you have more than street tire on it. They do stick amazingly well though.
Old 03-19-2012, 07:49 AM
FASTFATBOY's Avatar
Different offsets are required front to rear
http://www.jonaadland.com/Z28/Z28/Z28.html
Old 03-19-2012, 08:04 AM
RAMPANT's Avatar
Is that a Camaro thing?
I have 10.5" TTMs now and both front and rear are the same offset. Mind you they are different than the ZR1 offsets. I had a set of staggered TTMs, so again I was able to do a static test fit before buying a complete set of the 10.5" rims. There is a penalty withthat nice deep dish look of the TTMs, it has tighter brake clearance. I still run the stock fronts, but with Carbotechs.
I used to have a set of real ZR1s and got the 35mm offset, but had 4-5mm milled of them to make them roughly a 40mm offset and they were my initial test fit on the front. They did sit about flush on the rear and I had the fender wells rolled. These tuck in a little better.
I do recall some one that had a custom set of 17 x 11" wheels made, tell me they used 40mm offset front and rear.
Old 03-19-2012, 09:29 AM
whytryz28's Avatar
They would be pushed out further on the fronts if the same offset was used. I suppose I could throw my rear rim on the front to show one day but not now haha
Old 03-19-2012, 09:56 AM
FASTFATBOY's Avatar
A Firebird can accomodate more rear tire, it's fender is shaped differently.
This may be a Zr1 wheel deal, they made 2 offsets, a 5xmm and I think a 36mm.
The 5xmm goes on the rear and the 36 on the front to clear brakes.
Cant remember the rear offset though. Fifty something.
Been a while since I researched it.
Old 03-19-2012, 10:36 AM
firemech21's Avatar
Im running a 56mm offset of the rear. I want to get rid of my current ZR1s and get a full set of 17x11s for all four corners.
Old 03-19-2012, 10:41 AM
FASTFATBOY's Avatar
http://community.webshots.com/album/78350444Ciumpg
https://ls1tech.com/forums/road-raci...hat-tires.html
Go to FRRAX.com and search this topic.
Old 03-24-2012, 03:38 AM
98_1LE's Avatar
Old 03-25-2012, 10:13 PM
meine96ws6's Avatar
Looks good...
Old 03-25-2012, 11:45 PM
The Batman's Avatar
One of the things I like about running Deep Dish ZR1's all around, is that I can retain the factory look of the early firehawks. It sucks that the ROH firehawk wheels wont clear my Baer 13" track brake kit
Quick Reply: 17x11 zr1's all around
