18x9.5 appropriate tire size
A friend of mine has some used chrome 18x9.5 c6's on his car. The rims came with 255/50/18's. it looks very odd with that much sidewall. From behind it looks like a pair of pozza cutters. He asked me what size tires to run, and I had no real answer. He is wanting to do a 285 out back and maybe keep the 255 in the front but with a smaller sidewall. What should he run all the way around?
255/40/18 would be a more normal tire height but that is a fairly narrow tire for that width of wheel. I'd do 275/35/18 front and rear so you can rotate the tires,get the proper width tire on those wheels, and the proper tire height so it doesn't look weird and the speedometer will be correct.
I have 275/35-18 on mine. Heres a pic if this helps.
https://lh5.googleusercontent.com/-O...6/IMG_1282.JPG
