Whats the best 18" drag radial out there?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I only know of Nitto and MT making 18" drag radials. I heard Nitto was having problems with a lot of there DR but could be wrong? Anyone have the MT ET streets in 18"? Most racing will be on the street (1/4 and highway runs), I will have somewhere around 700rwhp with nitrous so does either of these get better traction?
thanks
thanks
Originally Posted by KingCrapBox
BFG makes an 18" Drag Radial. It hooks up much better than any Nitto I've ever seen. The only downside is that it has horrible treadlife.
I would think the BFG's treadlife is better then some ET streets
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
also what size should I go with? I just looked them up and they have
295/35-18 R Speed Rated Price Each: $210
and
315/30-18 R Speed Rated Price Each: $244
Could I take these tires to 140mph without problems?
damn there expensive!
Originally Posted by SStroked 410
I forgot all about BFG,
I would think the BFG's treadlife is better then some ET streets![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
and
and
and
and
The BFG's don't last for anything. A few good burnouts and you'll be wondering where your tire went. An ET Street will outlast a BFG drag radial by a LONG shot.
The speed rating is for a *sustained* speed of 140. If you run 140 in the 1/4, you're only seeing that for a couple seconds tops so your fine.
I need some 18" drag radials too, but I do alot of highway driving and don't think anything other than the Nitto's will last. The last set of Nittos I had though didn't hook for **** at the track and were worse on the street. I wish there was another option out there.
I was searching and couldnt find a 18" ET street? I heard they made one but maybe I am wrong.
I used to have Nittos on my 17's and they were ok. Got a lot of miles on them
damn I dont know what tire I should go with
I have the BFG TA DR's and not any complaints. I hook very well with a minor burn-out! So far I have cut .2 off my 60' times, more to come once I figure out the launch. See below...
Close up...
![](http://memimage.cardomain.com/member_images/11/web/515000-515999/515263_7.jpg)
Close up...
![](http://memimage.cardomain.com/member_images/11/web/515000-515999/515263_8.jpg)
You must be careful in the wet at the very least. Once the tread wears some lets say to about 3/4 used, driving in the rain will take alot of care not to overpower the tires or hydro plane. But for average driving or a weekend car or to from the track should be O.K.
