17x11 with a Pro-Kit?
Old 09-20-2005, 07:29 PM
AbsolutHank's Avatar
Default 17x11 with a Pro-Kit?
Anybody running this setup, with stock shocks? Any rubbing after the BFH mod?
Old 09-20-2005, 07:43 PM
skewba98z28's Avatar
You shouldn't have a problem after the BFH mod and in most case's and adjustable panhard is a must. Bird wheel wells are alittle bigger than the Camaro's
Old 09-20-2005, 07:50 PM
Yeah, I had pretty much planned on getting the panhard bar....I feel like I've read so much about this, its all a damn blur...anybody else with any advice or experience?
Old 09-20-2005, 08:06 PM
TXAgZ28's Avatar
I run 17x11 wheels when I autocross, and I have G2 springs. Those are about as low as an Eibach kit (but they're stiffer and don't suck ).
I got rubbing on the inside, which I cured with a 7/32" wheel spacer (and longer studs). I also had problems with the outer fender, so I used one of those nifty Eastwood tools to roll the fender. No more rubbing.
The BFH mod will work for you fine if you don't use a spacer. Just keep an eye on the outer fender lip.
What offset are your 11's?
Old 09-20-2005, 08:30 PM
SSilverSSurfer's Avatar
take the spacers off!!! gonna give you problems....i run 17x11 with a pro kit and the offset is 50mm....works and looks great....i just need to roll the frnder...the inside doesnt rub and i didnt do the BFH mod
Old 09-20-2005, 09:18 PM
TXAgZ28's Avatar
The spacers aren't going to give me any problems. Like I said, I only run the 11's when I autocross, and if I don't use the spacers, the tires rub the inner fenders in the rear, and the wheels rub the spindle dimple in the front.
Old 09-20-2005, 10:25 PM
joblo1978's Avatar
Yeah! Why are spacers a problem?
Old 09-21-2005, 07:44 AM
TXAgZ28's Avatar
They're not, so long as you get longer studs, which I did.
