BMW wheels on an fbody
would they work with an adapter?
The lugnuts are designed to center the studs in the lug holes, however if the studs are not the correct pattern they will have a sheer force on them when torqued.
Stew
Stew
To put it in perspective, 0.65mm is equal to 0.026", which is roughly half the thickness of a factory head gasket. That's the difference we are talking about here in bolt patterns. And with a 5 lug, take that difference and divide it by approximately 2 to get the actual difference at each lug nut, and now we're talking about 13 thousands of an inch difference.
120 mm vs 120.65 mm. We are talking about 0.65 mm difference, divided by half, meaning each lug would be approx 0.325 mm off of the correct bolt circle centerline.
0.325 mm is very small, probably even closer than the tolerance levels of these lug studs. Look on a metric ruler and see how small 1/3 of a mm is.
120 mm bolt circle (BMW) wheels should work just fine, and have proven to do so on these cars. Just make sure your lugs are torqued properly, to make sure.
that and some correct hub centering rings and your straight
