Bigger Tire Diameter? ABS? HuH?
Old 12-25-2006, 02:26 PM
Silver UltraZ's Avatar
Default Bigger Tire Diameter? ABS? HuH?
Alright Im running a 285/30/20 and a 275/35/19 which are a little bigger then stock what do you guys mean by the ABS fails? Someone explain please.. Does that mean if I ever have start to skid the ABS will not work? Im confised please help.
Old 12-25-2006, 02:44 PM
Kleeborp the Moderator™
MeentSS02's Avatar
The ABS sensors sense the wheel speed at each wheel on a 4 channel car and at each front wheel and the rear axle on a 3 channel car. All it is looking for is to make sure there isn't too much of a difference between the wheel speeds. If, say, the fronts locked up, their wheel speed would be zero compared to the rears that would still be spinning, and thus the ABS would kick in. Now, if you have rear tires that are a much larger diameter compared to the fronts, there will be a difference in wheel speed since the rear tires will be covering more ground per revolution. This difference in wheel speed could potentially be enough to confuse the ABS computer, and thus illuminate the ABS INOP light. At this point, ABS doesn't do anything at all. If you strap down on a dyno, it is the same concept...the rear tires spin while the fronts don't, and you get the ABS INOP light until you get off of it.
No ABS INOP light = no worries. If it isn't setting the light, then your ABS is still functioning properly. I run a 295/35/18 in the rear (a 26.1" tire) and a 275/35/18 in the front (a 25.5" tire), and the ABS computer didn't even flinch. I'm not sure what the threshold would be for confusing the ABS computer...never had the money or the desire to try.
Old 12-25-2006, 02:48 PM
The1N_only's Avatar
Im running 28's on the back and it trips the ASP INOP light, What do i need to do it make the ABS not work anymore, because if i get on the brakes a little on the hard side the modulate and it seems like the car doesnt want to stop. If i remember reading correctly you can pull a fuse. Maybe someone can shed some light on this
Old 12-25-2006, 02:52 PM
MeentSS02's Avatar
I just straight up got the SJM ABS delete kit for mine (but haven't installed it yet). I would think pulling the ABS fuse would get the job done...but never tried.
Old 12-25-2006, 02:56 PM
The1N_only's Avatar
as soon as i get the coin up, im going to get their abd delete kit along with the line lock
Old 12-25-2006, 03:06 PM
MeentSS02's Avatar
That's exactly what I did for mine...now I just need the time to install it.
Old 12-25-2006, 04:38 PM
Ok.. So what if the front and the back are the same size diameter but they are bigger then stock? Will the ABS still get pisseD?
Old 12-25-2006, 04:49 PM
The1N_only's Avatar
you will be fine, its only when the front and rear tires turn at a different speed
Old 12-25-2006, 07:04 PM
MeentSS02's Avatar
Tire diameter is the only thing the ABS cares about...wheel size itself is transparent to that system (as in it doesn't matter).
Old 12-25-2006, 07:22 PM
cws T/A's Avatar
Whats it look like
I dont have ABS no more , Moser 9'' 4.11's . I locked up my brakes on purpose the other day . Stops great , that was coming from a 120mph street quarter mile run I tagged 5th 6200 rev limiter in no time 156mph
