TTM/KDW combo rubbing front wheelwells
Old 07-28-2007 | 10:32 PM
71c10AZ's Avatar
Default TTM/KDW combo rubbing front wheelwells
I'm definitely an idiot for not doing enough research before I made a number of purchases . I have 17x9" TTM's (black) on all four corners with a -45mm offset (well within the range that was posted in the Wheels/Tires FAQ thread) mounted on 275/40 BFG KDW's. I had these mounted, balanced and installed today at a local Discount Tire shop, but they called me up during the install and notified me that the front tires rub the wheelwells (plastic portion) when either tire is clocked to the far right/left. Granted, I'm sure that pictures would be helpful but I'm not sure how to go about solving this problem. I'd contemplated about trimming the plastic, but I wanted a second opinion.
To make things worse, this issue is at stock height, and I recently purchased a set of H&R lowering springs (yes I did buy my LCA relocation brackets, too). What problems will I face with this with the exception of poor exhaust clearance and more rubbing issues?
Old 07-29-2007 | 04:06 AM
chevroletfreak's Avatar
I wish I could help, but I really don't understand why that size would rub? Maybe the trim is just loose?
Old 07-29-2007 | 04:50 PM
RevGTO's Avatar
Pontiacerator
Have you checked it out yourself personally? The front inner fender material is flexible and it's ok if it touches a little bit when nearly fully locked. You may not have a problem.
Old 07-29-2007 | 06:58 PM
blk00ss's Avatar
Dont worry about it at all. My TTII's with nitto 555's(275/40) rubbed that plastic piece, and my pro stars rub it as well.
Old 07-30-2007 | 12:52 AM
71c10AZ's Avatar
Thanks! I've been careful within the past two days of driving it, but the car hooks well with the KDW's for being practically a stock car.
Old 07-30-2007 | 01:21 AM
blk00ss's Avatar
yea those kdw's hook real good, ba buddy of mine had them on his and you couldnt hardly get them to break loose unless you popped the clutch!
Old 07-30-2007 | 02:08 PM
Xsta Z 28's Avatar
No biggie what so ever. Looks like this?
Old 04-09-2011 | 07:31 PM
fucter's Avatar
For the **** few; any easy way to fix this? Bfh?
Old 04-10-2011 | 10:52 AM
KingCdogg's Avatar
You can't BFH a plastic liner...
Old 04-10-2011 | 11:15 AM
Snaggle's Avatar
I is perfectly normal .When replacing my pads and rotors yesterday I noticed the same rub spot and im am totaly stock with 17" zr1wheels and stock springs and shocks. I guess they always rubbed even fron the factory.
Old 04-10-2011 | 12:28 PM
IWGF's Avatar
It's not a big deal... My old prostars and racestars did the same thing up front.
Old 04-10-2011 | 09:38 PM
Xsta Z 28's Avatar
A bracket to pull the liner away from the tire is about the only thing I can think of . . .
