Spray home insulation as extra sound deadening?
I am doing everything I can to deaden every possible sound in my car from the outside - from insulations under the carpet and on the walls and even sound proofing film on the windows.
I hope everyone on here knows that unless you plan on having passengers in the back, there is more harm than good done by keeping the rear speakers. I am looking for advice on filling the outer section of the rear panel with spray foam sound deadening like is used in houses.
Is there a downside to this?
Thoughts?
Thoughts?
I'd like to know why you think this? The speakers in the sail panels are mid bass, which produce very little highs. So, obviously they produce more bass, which won't matter at all where the location is, to a point.
Z-
This isn't a stock system. My fronts (it's a T/A) are CDT components rated to 300 watts/RMS/side. The bass is just an Alpine typeR, but when he wrote L'arlesienne, I doubt Bizet could have imagined 600 watts RMS!
So, if you need mid bass from the, err, mid speakers, you are dead on and my blanket statement was pretty dumb.
99-
Damn. That is exactly what I was afraid of. Thanks for the info. For ***** and giggles, I think I'll fill it with towels. I'm already in $550 on deadening, what's a bunch of towels going to cost from walmart on clearance. If it doesn't do anything, I'm only out $30-$40 more. Besides, it's like side airbags! Side towelbags?
Thanks guys.
99-
Thanks guys.
Save the manuals!
This is even a problem when using the stuff for its intended purpose in a structure. You need to have an expansion relief to release the pressure.
So, you could probably drill a bunch of holes in the interior panel to let the foam escape and relieve pressure. Not sure what that would do to the car, though.
There is a special type of low expansion foam for windows and doors (you can NOT get this at a hardware store) that would be better - but even this will cause problems. (The regular foam around doors and windows will deform the jams so they don't work correctly.) The low expansion foam will probably not cause the panels to explode, but it will probably cause them to bulge a bit and deform the shape of the car somewhat. (All expansion foams will build up pressure.)
If you want to deaden the space, I'd suggest using a loose fill insulation. (Like the type blown in attics.) That will fill up the space, deaden sound, and will not cause any pressure problems. You'd just need to find a type that won't rot when exposed to moisture, etc.
See, loose insulation, like my towelbags. Safety and insulation! I don't want to risk filling it. There is always a chance that I'll want a pair of 8" CDTs in the sail and possibly a better sub to take on only low bass. Who knows. And my towelbags are removable! I'll have layers of sound deadening there anyway, so this is really the tipping point just past sanity into overkill anyway! But if I change my sig, you can bet towelbags will be in it to confuse the hell out of people!
Thanks guys!
Thanks guys!
