Intermittent Voltage Drop
https://ls1tech.com/forums/generatio...tage-drop.html
It sounds to me like you have a weak, intermittent electrical connection and not a bad alternator. Start over by ensuring electrical connectivity going from the + battery terminal through the loop to the alternator and back to the - battery terminal. I would check the cable bolting into the - battery terminal, the cable bolting into the + battery terminal, and the power cable going to the alternator and possibly the signal/exciter wire at the alternator. After you've checked those few connections, then bring the alternator to autozone/o'reilly and have then do a test on it. If this all does check out, I think you have no choice but to begin tracing the wires.
The alternator should only need two wires - signal/exciter wire and power wire. My KG3 only had two.
I see you went through the hassle to enlarge some of the wires while you were in there. This splicing may end up causing you headaches as opposed to relaying a larger continuous wire
I may have the alternator tested tonight if they're not busy at the local parts stores. Thanks for your help thus far! It may be a while with me responding with results as I work late and usually only find time to work on the car on the weekends.
I want to put this into diagnostic generalizations. So, if my voltage experiences an intermittent drop, one of the following must be happening.
1. The PCM is not signaling the alternator to engage.
2. The alternator's rectifier is failing.
3. The alternator is failing.
4. There are faulty closed circuit connections.
5. A high load is momentarily placed on the system.
----A. Corrosion/Junk floating in the battery causing a temporary short.
----B. A Failing electrical component, ie when a fuel pump may be on it's way out, they may momentarily or constantly draw high amperage.
I'm not saying all of these are practical, but just trying to list all general conditions that could/would present themselves in the manner I am experiencing. I know some higher rated fuses may not fail the instant the current exceeds their rating, again generalizations, and if momentary, could go without burning itself up. This is unlikely, but possible. I guess after I get the alternator tested and check those ground connections as I was supposed to, I may start removing some circuits from the system attempting to single out the faulty circuit before shredding my wiring harness open to replace the alternator signal wire.
Thoughts? Additions to the list?
