Alternate Headlight Lifters?
I found these the other day and so far they are making me happy. https://ls1tech.com/forums/stereo-el...ght-doors.html Easier to change the gears and they are quieter than the old ones, but... I expect that will change with age.
IMO - These are the best option we have for a balanced set of features. I suppose one could use a linear actuator or pneumatics to control the doors, but finding a linear actuator that is quieter, will stand up to freezing/hot temperatures, vibration, water, etc. would be difficult and expensive. I'm not sure pneumatics would be a low maintenance solution, either.
The thing these motors do well, is adjust to wear over time. (Until they break.) It may seem weird that every time we turn on the car, the motors dance back/forth but it fixes THE big problem that pop-up headlights had way back when. Motors would start to wear and bind up and you'd have cars all over the road with limp lights or one stuck up and the other down. Ours are continually adjusting, so they either work or they don't. There's really no in between.
In the end, I think there are two flaws with the motors as designed:
- We can't change the gears with the motor on the car. (At least the new cardone design has screws to take the cover off to get to the gear - yea!)
- The motor casing attachment to the plastic gear housing sucks. As the tabs wear down the motor housing "hops" off the gear housing, which leads to gear stripping. (It seems that many gear failures are due to this.) I got to thinking the other day that a worthwhile project might be to come up with a metal gear casing that can be welded or more firmly attached to the motor casing. In addition to being more durable, it might also bring down noise. Is there anyone with a CNC machine in the house???
What I've found so far is this: McMaster-Carr sells "washdown" air cylinders, which are water- and chemical-resistant for around $120 per piece, and I've sourced a 12V 150psi air compressor with a 1.5 gal tank for about $150 that normally is used for an air horn. I'm still looking into the mounting issue.
An air system would be a great excuse to install airbags for the suspension, locomotive horn under the hood, etc. Do you think that air cylinders would be less maintenance than changing out a gear ever couple of years? (I've never worked with them and don't know how long the seals would last.)
As for a control module, between my roommates and myself, we have 2 mechanical engineers, 2 computer science/software engineers, and an electrical engineer. If we can't figure it out, I'm not confident that it could be done
The only thing I'm still unsure of would be the mounting. More updates hopefully to come.
after a quick google image search I found this and it is infact attached with a bolt, the mounting holes look so close to the fbodies
http://www.isimotorsports.com/produc...18336_zoom.jpg
94T/A - that's what I was after. Looks like at 2000 the corvettes changed over to the same motor in the F-bodies. (It looks like the motor height and mounting holes are different.) My theory was that the metal cased motors would be more durable. Do you know why you had to change the motor out on your corvette?
wssix - Apart from your post being totally broken...
I have contemplated doing a multi-position system, but as far as I can tell, the air cylinders I found don't have any way to do that easily and reliably. They seem to be just a basic in/out piston. I still think I would be wicked sweet to have the air powered headlight doors though. Flip a switch and the doors open up lightning fast with an ominous hiss...
I think it's a very plausible idea. The only thing holding me back right now is funds. If any sponsors want to get in on this.......
I'm thinking that I will use the air piston to not only replace the motor, but alter the movement slightly as well. I plan to fit a set of projectors (and maybe a couple other things) instead of the current lamps and then set the doors to open quite a bit less. Basically, they will only open far enough to reveal the projectors (under 3 inches), giving it a meaner look.
The plumbing is pretty straightforward. I've ordered an ultra-light duty onboard air compressor and 1 gal tank (designed for air horns) and I just need to get a 4 way, 2 position solenoid valve. Will post another update once fabrication gets underway.
