Jensen VM 9224 24 hour double din hot deal only $299.99!
Closed ex-Sponsor Account
I have from right now till 3:00 Wednesday 9/21 CST
This crazy deal on a
Jensen VM 9224
Double Din Package!
only
Jensen VM 9224
Double Din Package!
only
$299.99
Package Includes
1- Jensen VM 9224
your bezel sent to us and modified into a double din
1- GM Harness
1- set of installation brackets
1- GM Antenna Adapter
1- GM Harness
THIS WILL END TOMORROW AT 3:00 CST
WE HAVE TO PLACE ORDERS FOR THESE BY
3:30 TOMORROW TO GET THIS DEAL!
JENSEN VM9224 FEATURES
Integrates with iPods and iPhones
The USB input on this receiver has iPod and iPhone direct controls built in. This means you can simply plug your iPod or iPhone into the USB with the wire that comes with all iPods and it will play back through this receiver. In addition when your iPod is plugged in it will get charged. When your iPod is plugged into the receiver you will be able to use the touchscreen controls to change songs and operate your iPod. The built in iPod interface is for audio only. For iPod video viewing you will need a jLinkUSB cable.
USB Input:
Allows easy access for you to hook up any portable, MP3 player, or other portable USB audio device including a USB thumb drive with audio and video stored on it, or a portable hard drive.
High Power and Great Sound Quality
The receiver is rated at 40 x 4 watts, which is extremely loud. The ratings are actually tested by the industry standard. This receiver uses a MOSFET power supply which is known to power the speakers more efficiently. The lower end receivers use amps that are not Mosfet powered and they do not put nearly as much power to your speakers as one with a MOSFET power supply used by most of the premier brand name receivers, such as this one. This receiver will make your speakers super loud without having to purchase any additional external amps!
Aux A/V input:
The aux input will allow you to easily connect a portable audio or video device. It is an RCA Audio Video Input which means you will be able to transmit audio and video to the monitor through this one input. You can connect a video game system, digital camera, camcorder, navigation, VCR, or any other device you can think of.
Advanced MP3 Functions
A really cool feature that this receiver has is ID3 Tag display when playing back MP3 tracks. What this does is it displays the song name, artist name, and other info on the display of the receiver. You can also navigate the MP3 tracks by folder or song name and select which song you want to play.
Ability to connect multiple external amps
This receiver makes your car audio system expandable. The pre-amp outputs allow you to hook up external amps for your speakers without needing to purchase additional accessories. Since this has 3 sets of pre-amps you can hook up multiple amplifiers. This has front, rear, and sub pre-amp outputs so you can amplifiy all your interior speakers, and add a subwoofer amplifier.
Built in High and Low pass Crossover filters
This feature is only found in the top of the line receivers such as this one. The high pass filter will allow you to filter out unwanted noises from your full range speakers while the low pass crossover filter will allow you to filter out unwanted noises from your bass or mid-bass speakers. A crossover also allows your speakers to play louder without distorting. The reason for this is because you are filtering out the frequencies that cause the speaker to distort easily. The crossover also will make your speakers last longer because they eliminate distortion frequencies and distortion is what causes speakers to blow. With the crossover your speakers will last 10 times longer.
Expandibility:
Bluetooth Ready (Requires BTM15)
When you connect the optional bluetooth interface (BTM15), the receiver will display all your caller ID information and mute your music automatically, when you receive a phone call! When you talk using the hands free, the sound will come from your car speakers, and you can listen and talk freely!
Steering Wheel Control Ready
You can control the receiver directly from your stock steering wheel controls with the optional SWI-PS
Navigation Ready
The VM9224 is navigation ready. Navigation requires the NAV102. This will have totally advanced navigation features. (See NAV102 product in our store for navigation features).
Features:
New Jensen VM9224 6.2" TFT Touch Screen , all-in-one in-dash monitor receiver
Double din sized with perfect fit panel
AM/FM/MPX Radio
DVD/CD, USB Receiver
Full Function, Soft Touch Screen
Built in iPod and iPhone audio interface
iPod video ready - requires jlinkusb
16:9 Wide Format or selectable 4:3 aspect ratio
Anti Reflective screen coating
Fixed Panel
High Resolution & Definition Picture
36 Preset memory Radio Stations
Built in crossover filter
Sub controls
Auto Loader DVD/CD Deck Mechanism
Plays DVD, CD, MP3, Xvid, MPEG1, MPEG2, CD-R, CD-RW, and WMA
Built In ESP
Zoom In/Out Function
Last Position Memory
USB in Front
Multi Language OSD
Rotary control **** for easy navigating
Navigation ready (requires NAV102)
(2) Auxiliary AV Inputs
Rear View Camera w/Reverse Gear Sensor
(3) Sets of Front, Rear, and sub Preamp Outputs
40 x 4 watt 4 Channel High Power Output
8 Preset Equalizer Curves
Composite video output allows you to add additional video screens
Steering wheel remote ready (Requires SWI-PS)
Advanced easy to use touch screen interface
Front aux A/V Input
Front and rear USB
USB and SD can play both audio and video files
MP3 ID3 tag displays artist names, song names, album names, etc
Secondary display for when screen is in the closed position
Blue button illumination
Includes A/V Media cable
Bluetooth ready (Requires BTM15)
i have one of these left. Had a customer wreck his car and cancel order
So
I sent a message to mthegodfather for first dibs.
anyone else interested let me know
Dennis
So
Dennis
