ground loops and how to get rid of em'
please inform.
my electrical system is unmodified exept for a relocated battery.
the ground comes out of the battery and goes to the frame. there is one power wire that doesnt go to the frame but goes to the battery. and there is one ground wire that goes to the battery that goes to the body, not the frame.
up at the front of the car the block is grounded to the frame and then the normal stuff you see under the hood that is also grounded to the frame in lots of little different spots.
i'm not trying to get rid of speaker noise but since you mentioned it my amp is grounded directly to the battery
each with a "ground", but they are not the same point in an
electrical sense; you can have DC offset, you can pick up
EMI from power line (in a 60Hz environment, making hum),
if the signal ground is the same as your power return you
can feed back switching / load transients and like that across
the resistance / inductance separating the points.
A "star ground", everybody to the same post, is ideal. But
that is more copper, copper is weight and money, and the
chassis sheet metal is "good enough" for the average buyer
and the factory stereo.
