cant find weather resistant 12 relay!
i'm beating my head against the wall for this one.. dont know why i can't locate what i am looking for
call it weatherproof, watertight, waterproof, sealed, weatherpack something.. all i want is a 12vDC automotive relay that has the ends sealed to keep out moisture and can be exposed to weather. can be with our without a harness (have only seen them with a female plug and harness that it snaps into)
it has the ribbed silicone seal just like all of our stock connectors have...
help!
help!
What you need is a weatherpack 280 series relay,I just replaced the one on my 97 Pontiac sunfire, used for the DRL's.There is also one used for the ignition switch recall campaign for the same car.The GM part number is 12193601 that is a 5 pin spdt relay.
You can see all of the terminals and seals available here.
http://www.electerm.com/packard.html
Hope this helps.
Hope this helps.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
help!
help!
Ask and you shall receive.I am sure this is what you want,but here is the image for you anyway.
thanks man, $16 bux is a lot more realistic.. i wish i could see a photo to know for sure
Here use this number it will give you the relay,connector,wire leads with terminals and seals already attached and the mounting bracket.
22694036
22694036
well looks like the top half of it anyway.. where do i get the bottom half with the rubber peice and the base that clips in?
i ran across these now too... probably the same thing
https://www.casperselectronics.com/M...Category_Code=
