question about my new infiniti's 6.5's
I recently installed some infiniti's 6.5's in my sail's. They are the 62.7i. I have the stock monsoon headunit. It seems like there is too much bass right behind my seat. It rattles a little. Is this a good speaker to use or was it a waste of money?
If I use some kind of sound detening(dynomat) material behind the speakers, will this help with the sound or what?
Please someone help. Thanks!!!
Did you run the wire going to your far rear 4 inch speakers to the tweeter input on the 62.7i or are you just using the woofer input and not using the tweeter. I noticed the 62.7i was bright when right behind my head, but I didn't notice too much bass...I did add sound deadening in the hole though and I hear no rattles. I also have the front and rear fader set to slightly more front and sounded much better.
The signal that goes to the sail panel speakers is only bass, it's crossed over in the monsoon amp. I don't think you will get great sound out of the infinitys without some rewiring. You are better off replacing those with a set of small subs if you want to retain the monsoon amp. I'm not infinity bashing as I have them in my sails as well, just aftermarket amped, and wired for highs.
