Anyone install a satellite radio on a t-top 4th gen?
Hey guys,
I just picked up a satellite radio, and the antenna doesn't stick to the roof as expected. Have you guys come up with any good solutions to this problem? I wonder if the signal will be good if I just mount it on the windshield in front of the rearview mirror.... Thanks in advance.
Fikret
Fikret
Copy & Paste Moderator
i put mine under the black plastic windshield cowl on the passenger side.
if you go that route, just make sure you dont place it where that wire mesh is over it. works perfect.
heres where NOT to put it:
http://pics.montypics.com/badhoopty/...70072_copy.jpg
i originally had it there and got real spotty reception, i moved it a few inches more to the left out of the way of the wire mesh and it works perfect.
I ditched the ugly 'bump on a frog' supplied antennae and went with a Terk Amplified thru the glass antennae. It's mounted in the center top of my hatch glass.
Antennae sticks to the glass on outside, there is a matching part that sticks on the glass directly behind it, and I ran the wires thru the headliner and down the PS A-Pillar to the radio.
The amplified version picks up much better even when surrounded by tall buildings in town or in a valley between mountains while driving.
-Jay-
-Jay-
Do any of you guys have your satellite radio connected via the XMDirect adapter, the one that goes right to your headunit. I have XMDirect hooked up to my HU (Excelon 890), and I set the display to show the channel, artist name, and song title.... and it keeps on flashing "Waiting" then the channel name, "Waiting" then the artist name, etc... I mean, it works and sounds great and all.. but that bugs me a little that it keeps flashing "Waiting" like that.
Anyone know what the problem may be????
Hey 1QUIKWS6...can you post where you got that amplified terk ant???? I have XM in my Jeep, and I want to be set up in the TA so that I can just toss the reciever in and use it in either car. But I hate running wires from the outside to the inside. The ant you have sounds like it would be perfect for what I want to do. Thanks for any info you can provide!!
Justin
Justin
Had some time this morning; I ended up installing it right behind the rearview mirror for now. I used the suction mount that came with the kit, but fabbed up a steel plate on there so I could use the magnetic feature of the antenna to make it stay. Right now, it sits perfectly flat, and seems to have a good all-around view out the windshield but I still get pretty crappy reception. The funny thing is though, the signal gets worse when the car is moving, and when I stop it gets better. Also, the clarity is much better when the car is turned off and not running. I wonder what may be causing this...
Ungrounded Moderator
Because the satellite signal is digital, it won't fade in and out like normal radio. The signal strength will vary but the radio will play the same until the signal gets weak enough that it just cuts out totally. You can switch the display to the signal strength meter and drive around to see how much the signal is changing and how good a signal you're getting with the antenna in its current position.
