keyless entry
Old Jan 25, 2007 | 02:17 PM
Pretyflywiteguy's Avatar
Default keyless entry
94 trans-am and 94 camaro. Both have it and both suck. I have to press the button repetedly and sometimes over 10 times. What causes this? I already changed the batteries in each remote. Any ideas?
Old Jan 25, 2007 | 03:10 PM
VIP1's Avatar
Copy & Paste Moderator
Which button?
How far away are you?
All remotes or just one?
The keyless entry system in the 4th gen f-body has a short range.
Old Jan 25, 2007 | 04:13 PM
standing right next to the car. all remotes and all buttons.
Old Jan 25, 2007 | 06:54 PM
VIP1's Avatar
It may be a problem with the car's transceiver.
I don't know where it is or how to fix it though.
Old Jan 25, 2007 | 09:36 PM
well than what good are you!?! lol j/k
anybody else have any ideas?
Old Jan 26, 2007 | 07:57 AM
WhiteBird00's Avatar
Ungrounded Moderator
The receiver is built-in to the BCM.
Old Jan 26, 2007 | 11:50 AM
TheGr8Schlotzky's Avatar
this happens to me too in my camaro. "resynchronizing" it seems to help at least a little bit.
Get in range of the car (stand right next to it to be safe) and before unlocking it and getting it, hold the lock and unlock buttons at the same time for about 7 seconds. The car unlocks and relocks to show it accepted it.
It might not help in this case, but it helps me in my similiar problems sometimes.
Good luck.
Old Jan 26, 2007 | 01:05 PM
tried what you said gr8schlotzky and it helped a little bit, it's better than it was.
Old Jan 26, 2007 | 11:45 PM
VIP1's Avatar
Here is a thread I dug up:
https://ls1tech.com/forums/showthrea...43#post6325043
It doesn't have a solution either, but I responded in there recently thinking about possible solutions to increasing the range.
Old Jan 27, 2007 | 06:33 AM
HiTechGent's Avatar
The micro-switches under the buttons wear out. Probably time to get a new remote. Unless you're good with a soldering iron and can locate the appropriate replacement parts.
