Door Chime
lol undo the dash under the steering wheel and look for the little dox that looks like this..
![](http://i49.photobucket.com/albums/f253/pretyflywiteguy/DSC01851.jpg)
then yank it out and throw it at your house then spit on it and cuss at it then put it in your garage until you go to sell the car.. at least thats what i did
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ungrounded Moderator
then yank it out and throw it at your house then spit on it and cuss at it then put it in your garage until you go to sell the car.. at least thats what i did![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
You don't want to disable the door open switches because that will affect the RAP circuit. If you just want to disable the ignition key warning then the best way is to disconnect the light green wire in the blue 32-pin connector at the BCM (there are two light green wires - you want the one in the row closest to the connector's locking tab). This will disable the key warning chime but it will also disable the lockout prevention circuit so be careful not to lock your keys in your car.
Originally Posted by WhiteBird00
Yes, you're right but I think he's talking about leaving the key in the ACCY position to run the sound system with the doors open.
Originally Posted by Blacker
I believe there is a modification on the FAQ for adding a switch to disable/enable the door chime. Looks really simple to do.
I remember that one - it even had pictures. It's doesn't seem to be in the FAQ anymore and I couldn't find it with a search. It was basically the same thing except instead of just disconnecting the light green wire he added a switch inline so he could disable the key warning only when he needed to.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
