A couple of Alpine SPS-17C2 questions
Old Apr 5, 2007 | 07:34 PM
ss1's Avatar
ss1
Default A couple of Alpine SPS-17C2 questions
I've purchased a set of Alpine SPS-17C2's (newer version of SPS-170A's) to replace my stock monsoon door speakers. I have already read all of the stickies and topics on this upgrade. The 17C2's terminals look a little different than the 170A's so I still have a couple of questions I need answered.
Door Speakers:
Do I need to leave the capacitor on the (+) positive side of the tweeter, or will it work without it? (I've haven't found a definite answer, although one writeup says to leave it in there.)
Can I leave the (-) ground wire on the tweeter attached to the (-) ground terminal for the midrange? As a common ground point I guess you could say, or will this cause a problem? (My guess is it would be better to keep them seperate.)
Sail Panel Speakers:
If I buy these speakers to replace my sail panel speakers, I would pull the hatch wires forward and do away with the hatch speakers.
Do I just forget about the original sail midbass wires, attach the hatch wires to the new Alpine speakers and everything works great?
OR
Do I need to separate the midrange and tweeter, and wire them like the door speakers? Ie: use the sail wires for the midrange, and the hatch wires for the tweeter?
I Just want some final clarification. Thanks!
Old Apr 5, 2007 | 08:12 PM
WhiteBird00's Avatar
Ungrounded Moderator
Leave the capacitor.
Separate the ground leads for the mid and the tweeter (important).
If you pull the hatch wires forward they will provide a full-range signal. Leave the original sub wires unused and it won't be necessary to split the leads on the coax speakers you put there.
Old Apr 5, 2007 | 08:45 PM
ss1's Avatar
ss1
Thank you for the fast response!!!
...and for not telling me to do a search
Old Apr 6, 2007 | 03:12 PM
02 Silver SS's Avatar
Just do what I did install all new wiring and system
Old Apr 6, 2007 | 08:43 PM
ss1's Avatar
ss1
I've got a blower, I could give a **** if my stereo blows out my eardrums. As long as the speakers work and I can listen to music, i'm a happy camper.
Old Apr 13, 2007 | 12:43 PM
LS1DER's Avatar
I was sitting here researching and came across your thread. I am wanting to use the alpine sps-17c2's also in the front and in the sail panels. From what I've read I need to pull the wires from the rear speakers and use those for the sail panel speakers. To go along with what was asked above, is the power output(from the amp) used on the rear speakers enough to power the alpine's. Also would there be any advantage to wire them like the door speakers using the sailpanel midbass and the rear wires to power the alpine's. I just read earlier about how low powered the rear speakers are. I didn't know if that would help distribute the power a little better. I know what I'm trying to ask in my head but it doesn't seem to come out the same way when I type it. Hopefully someone can understand what I'm trying to ask.
Old Apr 13, 2007 | 12:58 PM
You can install the Alpine speakers in the sail panels as you mentioned but it will sound completely different from the stock sound. You won't have the bass that the stock subs provide. You should consider adding an amp and sub if you go with coax in the sail panels or else put some midbass subs in the sail panels instead of coaxials.
But to answer your questions...no, don't split the coaxial into components for the sail panels as you do with the doors (at least, not in a Camaro). The wiring from the single 4" speakers in the hatch area of a Camaro provides full-range signal and is quite powerful enough to run those Alpines as rear fill. That's all you really want from rear speakers. Many people will try to tell you that you should only have speakers in front to produce the proper sound stage but many of us enjoy the surround sound effect. Even still, you want the front speakers to be the focus and the rears to just fill in the sound.
Old Apr 13, 2007 | 02:26 PM
LS1DER's Avatar
All right thanks. idk, I'm still undecided. I think for now I'm just going to do the door speakers b/c they are the ones that are blown.
ss1, Have you put the new speakers in yet? if so how do they sound?
Old Apr 13, 2007 | 02:57 PM
fredmr39's Avatar
Originally Posted by ss1
I
I know this thread is a week or so old, but if you were wondering WHY the "grounds" should be separate, it's because they aren't "grounds". In a typical speaker, oscillating currents induce magnetic fields in the coil which causes it to attract or repel from the permanent magnet - which moves the speaker cone in and out, sending pressure waves into the air and into your eardrum. So the reason the speaker cone moves in both directions is because the current alternates in both directions, and that causes the polarity to reverse. So...you can imagine if both were hooked up to the same "negative" terminal and you were mixing signals, etc...since each speaker obviously receives waves of different amplitudes and frequencies.
Sorry for the boring explanation - just felt you should know if you didn't already. Reason is, one of my roommates cousins asked me why his speakers weren't working, so I look at them last time he was here (actually 2 weekends ago)....and only one terminal is connected and found the other (negative) wire on some screw in the door because someone decided to treat it as a ground (he claims the previous owner...).
Old Apr 13, 2007 | 03:12 PM
That's true of a floating ground system such as the Monsoon. However, there are common-ground systems out there (mostly cheap stuff but the old Bose was common ground) where all speaker grounds were connected together to chassis ground. Floating ground systems use half-phase signals (basically alternating current) whereas common ground systems use full-phase signals on the single positive wire (sort of like amplitude modulation). Don't ever mix floating ground with common ground - unless you have a good fire extinguisher handy.
Old Apr 13, 2007 | 03:42 PM
fredmr39's Avatar
I had no idea common ground systems in mobile audio were even around still.....that's what I get for being young and ignorant.
You said "old Bose stuff" -- how old?? Earlier 4th gens use floating, correct?
Old Apr 14, 2007 | 07:42 AM
ss1's Avatar
ss1
Thanks for the explanation of the floating ground vs common ground guys. I understand electronics, but not much about stereo systems. The more I know, the better!
LS1DER, I haven't put thes peakers in yet. I have a bunch of projects to do to my car over the summer and haven't started on anything yet. I decided on these speakers based on the positive reviews of these and the SPS-170A's. I don't need a system with a lot of bass, so as long as I don't feel like i'm listening to a tin can, i'll be happy.
Old Apr 15, 2007 | 10:41 AM
The early 4th generations were exactly the systems I was think of. They use a three wire system to each speaker - audio positive, 12V positive, and common ground. The 12V positive was for the individual amp connected to each speaker and the single ground wire provided both electrical ground and audio return path.
You don't see many common ground systems anymore because the circuitry that supports floating ground has become cheap enough that even entry-level systems can afford to include them. But back in the day (8-tracks dontcha know) common ground systems were popular and were often used as OEM equipment. It made vehicle wiring cheaper and easier since only a single wire had to be run to each speaker (they grounded to the chassis near the speaker). Today you can still see common ground systems on some 5th wheel trailer setups where the audio is passed from the tow vehicle to the trailer for the same reason - less wires to connect.
Old Apr 15, 2007 | 10:47 AM
fredmr39's Avatar
^^^ Awesome, thanks for the info!
