need HELP...want to install my sound system..HELP me
ok..this is what i have so far.. can anyone draw me up a detailed diagram as to how to hook all this stuff up, also what kind of amp kit would i need to power this up (what size gauge wire , ground wire etc...)..i really want to do it on my own.(with everyones help from ls1tech.com) if i left any information out that you need to know, just let me know..thanks so much
pioneer avh-p6800dvd (double din)
subthump rear enclosure box..ported for 2 10's
2 jl 10w3v3-4 (300 rms each)
jl 500/1 amp
coming soon... capacitor (please reccamend me one)
jl 500/1 amp
Here'a a link to the sub wiring diagram
http://img474.imageshack.us/img474/9...4ohmto4ohm.jpg
Read this if you still want a cap I have a brand new one I'll sell ya cheap.
http://forum.realmofexcursion.com/sh...ad.php?t=17970
BTW might want to get a drink and a snack it's kinda long. plus I had to read it a couple of times to understand what he was saying.
Hopefully this can help you a bit.
![](http://i205.photobucket.com/albums/bb23/SS2906/Steven/AmpWiringOutlay.jpg)
1. Typical setups use 4 gauge wire from the Battery to the splitter in the back of the car (13-14 feet should be enough). You mentioned only 1 amp, but you might as well wire it for more if you plan on adding a second one later.
2. Run 8 gauge wire from the splitter to the ampifier.
3. Use the same setup for the ground setup, with the exeption that your grounding source should be no more than 3-4 feet from the amplifying units.
(I used the seatbelt bolt, but make sure you grind the paint down to the bare metal or you'll be stuck with the engine whine)
