Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
- Chevrolet Camaro 2010-2015: How to Install Subwoofer
Step by step instructions for do-it-yourself repairs.
93 camaro, BOSE system, Wiring HELP
I bought my camaro from some guy who messed up the wiring pretty bad, but did manage to get his after market cd player hooked up and working. He removed his before the sale so i was forced to install my own. I've installed many CD players and systems and this one is kicking my A**. I'm pretty sure it has the BOSE upgrade or whatever, says it on stock head unit. I purchased wiring harness (correct one) and soldered each wire correctly. First problem i faced was the fuse was missing, replaced it and now CD player turns on and plays CDs. Problem is that their is no sound coming out of any speakers!!!!! The door speakers are brand new ($150). ANYONE HAVE ANY SUGGESTIONS OR ANYTHING...............PLZ HELP
there is only one bose amp and it runs the "subwoofer" in the rear hatch. the rest of the speakers (i think there are only 2 other ones...) are run off of the head unit. maybe that will help.
Not sure if it's just for the sail panel speakers, all of them, or some other combination of them. But I would check that out as well.
Ungrounded Moderator
Amazing amount of incorrect information about Bose systems here.
The Bose system was the premium audio option on Camaros only between 93 and 96. It was available in a 3-speaker configuration and a 5-speaker configuration. Both versions had full-range door speakers and a subwoofer mounted in the left rear hatch area. The 5-speaker version had sail panel mid-range speakers as well. The system used a special head unit that output low-level, high-impedance signal to individual amps attached to each of the speakers. None of the speakers were connected directly to the HU. The individual amps powered low-impedance speakers wired with a common ground setup (almost all other modern systems use floating ground).
The amp in the right side sail panel below the speaker (next to the rear seat cushion) was only used in the Firebird premium audio system which was a 10-speaker system very similar to the Monsoon.
i am having a similar problem, i have the 5 bose system and i put in 4 new type r speakers, a 3000 watt power ackoustic amp, a kenwood head unit and 2 12' type r subs. WHen i the radio is on i get sound to all the speakers but like barely any power to the subs. However when i put in a cd or a dvd i get NO sound to any of the speakers but full power to the subs. I kno the factory bose amp has to come out but then where do i go from there? i checked all the wires and connections and they are all done right in the back of the head unit and i checked and played with all the settings on the radio and still nothing, any advice would be much appreciated, i've done many systems but this one is giving me and my friends major problems
mine does the same thing, i have the 3 speaker setup (i think) when i put a cd in NO SOUND????
and can i hook up 2 more speakers in the sail panels?
also how do i be sure that im not supposed to have the 5 speaker system??
