door speaker problem
hey guys... i had a blown pass door speaker, and went ahead and replaced it with a kenwood 6.5" 3-way. went ahead and did both doors, but the drivers side is golden. on the pass side, when i turn up the volume to a certain point, it starts crackling like it is goin bad... but a brand new speaker.
im gonna swap out the pass/driver speakers tomorrow and see if that speaker is bad. any ideas what it could be? thanks
Ungrounded Moderator
It's unlikely that the amp is causing your problem - they hardly ever fail unless abused. The doors are wired for components and 3-way (or coaxial) speakers aren't a good choice for replacements. Chances are you've wired the passenger's side speaker to the tweeter wires instead of the woofer wires (so you don't get a full-range signal) or that you've mixed wires from the two pairs.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I don't know that wiring the two outputs together like that is a good idea.
You're right...wiring the two channels together is like bridging an amp that isn't bridgeable. At low volume it's probably okay but it will fry the amp when you crank it up to higher volume.
yea. youll need the component set-up. like in my step bros stang, theres a box that you connect the speaker wire from the head unit to... then it has two other sets of outputs one to the tweeters and one to the woofers. but connecting the two together to the main speaker wires is not a good idea... like whitebird said. itll work at certain volumes and power levels, but when you exceed the ratings for paricular speakers theyll do whats happening.
