Pick me out a cam!
Old 01-17-2012, 12:47 PM
superbean's Avatar
Default Pick me out a cam!
I have a stock 5.3L swap in a g body malibu.. runs fantastic.. but the key to rulling well and damn good in an ls is a cam swap and good tune.
The car has 3.73s... TH350 with 3600 stall converter.
This is just a street strip car that I want to make some sound as well as move the shiftpoint somewhere around 6200-6400 rpm.. with rwhp number of 350.
Also, it is a factory bottom end and I need something that wont have an ptvc issues!
Thanks!
Old 01-17-2012, 02:56 PM
JPH
JPH's Avatar
Originally Posted by superbean
i have a stock 5.3l swap in a g body malibu.. Runs fantastic.. But the key to rulling well and damn good in an ls is a cam swap and good tune.
The car has 3.73s... Th350 with 3600 stall converter.
This is just a street strip car that i want to make some sound as well as move the shiftpoint somewhere around 6200-6400 rpm.. With rwhp number of 350.
Also, it is a factory bottom end and i need something that wont have an ptvc issues!
Thanks!
228/232 .585/.590 112
Old 01-17-2012, 03:42 PM
'02 WS6's Avatar
^ That would be a healthy cam for your combo. Also can't go wrong with the TR224.
Old 01-17-2012, 03:43 PM
Badmeat's Avatar
224R, 228R, Streetsweeper, MS3, EPS 226/230, Torquer V2/V3, custom grind....the options are near endless for a "street/strip" cam
I picked a 230/238 after talking to Geoff at EPS. He said that's about the largest he'd go to have well-mannered streetability. It's a good recipe for over 400whp LS6 with full bolt ons.
https://ls1tech.com/forums/generatio...veability.html
Similar threads I've seen:
https://ls1tech.com/forums/generatio...ns-thread.html
https://ls1tech.com/forums/generatio...-size-cam.html
Old 01-17-2012, 08:43 PM
garygnu's Avatar
what intake will you be using ?what are the head casting numbers ?go to comp cam quest 6 and plug in different cam grinds to see if a cam meets you needs.
Old 01-19-2012, 12:32 PM
superbean's Avatar
I'm using a truck intake. Compression ratio is 9.5:1 and stock lm7 01' cyl heads
Old 01-19-2012, 01:36 PM
wildcamaro's Avatar
I wouldn't run anything bigger than any of the 224 cams...all of them are very similar
As long as the cam's lift is under 0.600" you will be good on the ptv issues
Old 01-19-2012, 06:57 PM
superbean's Avatar
Why not any bigger than a 224 duration spec?
Old 01-19-2012, 09:43 PM
garygnu's Avatar
you have a smaller motor with not great flowing heads,no need for a big cam.look at comp 54-455-11.torque is your friend.
