View Poll Results: Which Timing set
LS2
18
46.15%
Katech
12
30.77%
Double Roller(JP,SLP etc...)
9
23.08%
Voters: 39. You may not vote on this poll
Which Timing Chain
Old 02-11-2009, 08:09 PM
witry's Avatar
Default Which Timing Chain
im doing a cam swap on my car and i have everything i need but cant decide on a timing set there are so many different choices and alot of them have been already talked about here but there is no defenate answere to swich is the dominate set
its between a ls2,katech,double roller
the car is gettin an LS6 cam with patriot double springs and 8psi on a rear mount on a stock LS1
Old 02-11-2009, 09:32 PM
SOMbitch's Avatar
Katech C5R money no issue hands down.
Old 02-11-2009, 09:34 PM
witry's Avatar
would you also recommend doing a new cam and crank sprocket or just the chain?
Old 02-11-2009, 09:46 PM
JFM-jr's Avatar
short thread some usefull info for you
https://ls1tech.com/forums/generatio...ain-slack.html
Old 02-11-2009, 09:48 PM
1999FirehawkLS1's Avatar
katech is were its at.
Old 02-11-2009, 09:54 PM
01ssreda4's Avatar
ls2, i did mine with sprockets. i figure a tiny bit of extra insurance.
Old 02-12-2009, 12:09 AM
luckyhenriksen's Avatar
I bought a JP double roller kit, it looks nice and comes with new sprockets. About 85 from sdparts
Old 02-12-2009, 04:42 AM
vettenuts's Avatar
Another option is the Cloyes IRL chain. There is a thread in the internal Gen IV section on these chains with photo's.
Link
Also, if you go with the Katech make sure it is the real deal. There are some less expensive knock-offs around now. Price will tell you quickly.
Old 02-12-2009, 09:40 AM
LSX Mechanic
Damian's Avatar
The LS2 chain is fine. Everybody has been freaking out lately because people have been breaking them on the Vettes, which has not been the chains faults. It's due to the harmonics (or lack thereof) of some of the pulleys being used.
I use LS2 chains on almost all of my builds and haven't had any problems in almost 2 yrs.
Old 02-12-2009, 09:42 AM
vsocks1's Avatar
What pulleys are you using on these builds?
Old 02-12-2009, 09:46 AM
wht01ws6ta's Avatar
I went with an LS2 and have had no issues but that is just me. I don't doubt that Katech makes a better product, if nothing else it fits tighter.
Old 02-12-2009, 09:47 AM
streetassasin's Avatar
Im going to use a ls2 when my cam goes in
Old 02-12-2009, 09:59 AM
LSX Mechanic
Damian's Avatar
On the F-bodies, either the ASP or Powerbond is fine. On the Vettes I've used the ATI unit or the stock one. I don't recommend the ASP on the Vettes anymore.
Old 02-12-2009, 10:19 AM
wht01ws6ta's Avatar
Ever had a problem with an SLP?
Old 02-12-2009, 10:30 AM
tillery's Avatar
SLP is a repacked powerbond. Your fine.
Old 02-12-2009, 10:47 AM
witry's Avatar
so you wouldnt recommend the one from summit i this its like 150 bucks but its summit brand?
Old 02-12-2009, 12:30 PM
LSX Mechanic
Damian's Avatar
I've never had a problem on an F-body PERIOD with any of the chains or pulleys. It seems to be a Corvette only design thats breaking them lately due to harmonics issues.
I've used SLP, Powerbond, ASP, ATI, etc etc etc on F-bodies and neither has given me a "problem". However my pulley of choice on F-bodies is the ASP, because it is the lightest of the choices.
Old 02-12-2009, 01:58 PM
witry's Avatar
^^^^^^^thanks for your info
Old 02-12-2009, 02:01 PM
99_SS_LS1's Avatar
fwiw, i run the ls2 with a way more aggressive cam (ramp rates & lift) than the ls6
Old 02-12-2009, 02:14 PM
witry's Avatar
^^^^thanks also you guys that run the LS2 set up do you run the tensioner or just the chain and sprockets
