Trans Am intercooler size
Can someone measure the distance between the foglights on the LS1 TA front bumper cover. Need to know how wide I can make the heat exchanger for the H2O to air. My car is about 1500 miles away. Thanks.
my i/c is 33x12x4
i cut most everything off the fog light brackets and attached them directly to the i/c with velcro....yes velcro and nobody has ever known. I take them out at the track in the summer for a little more airflow to the i/c. I dont like the way the front looks without the fog lights which is why i did it that way
my i/c is 33x12x4
What IC did you go with? OFI one is smaller 22x12x4, been thinking of getting a bigger one myself.
intercooler
here is a pic of mine, I believe it is a 24, all i know is i had to do v bands and tight 90's.
https://ls1tech.com/forums/forced-induction/747523-f1a-ls2-402-build-progress-pics-inside.html
This is going to be the heat exchanger for the water to air intercooler, not an air to air. The actual IC will be mounted inside. So I figure the heat exchanger can be 30" x 7"-8" or so. That should provide plenty of surface area.
