400+ cam only cars!!!
Old 06-09-2008, 03:37 PM
Black FormulaLs1's Avatar
Default 400+ cam only cars!!!
i have a 99 formula M6 car..right now she is getting forged goodies and she has every upgrade i can get right now w/ the acception of under drive pulley, and expensive intake set up...everything else is done...
i am currently running a lunati 234/236 .050 .544/.545 112 lsa cam...i made 380 rwhp and 350 tq when tuned and dynod...i am looking for the 415+ hp and more torque from a cam only set up...and since everybody is going to ask about my mods...i will list ahead of time...
slp lid, SLP cool air pak, K&N filter(s), smooth bellow, 80 mm BBK TB, LS6 intake, MSD wires, NGK Plugs, 853 heads( 3 angle valve job, new locks, guides, retainers) comp hardened pushrods, crane springs .650 lift,crane lifters, ported LS6 oil pump,dbl roller timing chain,polished crank, mahle forged pistons, eagle forged H beam rods, SLP Lt's, 3" ORY loudmouth w/ tips, no cats, no converters...i think that's it...and since suspention stuff doesnt really count on this..i will leave it out..
anyways like i said i am looking for that 415-430 hp cam only #'s
Old 06-09-2008, 03:54 PM
Bryan @ Speed Inc.'s Avatar
are you looking for e.t. improvements, or just a dyno number? i would recommend going with a FAST intake to make the most of a cam only combination. that way you might not have to go with such a ginormous cam to hit the number.
we have hit 410rwhp recently with our SI6 cam and ls6 intake (cam-only) for what it's worth.
Old 06-09-2008, 04:20 PM
looking for 420+ and atleast 400ftlbs..
Old 06-09-2008, 04:44 PM
ttt..............
Old 06-09-2008, 05:04 PM
ProjectDuStU's Avatar
Link to cam-only thread, not all at your goal but that gives you an idea of the cam size, also if you are gettin forged pistons, get some with valve relief and have your heads milled for bump in comp., A trex or a ms4 should do it for you.
https://ls1tech.com/forums/dynamometer-results-comparisons/219024-cam-only-dyno-thread.html
Old 06-09-2008, 05:54 PM
thanks for the link!!! if you got the #'s i am lookin for ..post up with how you got em!
Old 06-09-2008, 05:58 PM
35thz28camaro's Avatar
my a4 camaro made 401hp and 358tq cam only with the ms4 cam. with a m6 it should be close to what you want
Old 06-09-2008, 06:50 PM
01ssreda4's Avatar
i have heard of a torquer v3 hitting 419 hp. pm hilton for details.
Old 06-09-2008, 06:55 PM
Paint_It_Black's Avatar
those lobes on that lunati cam are pretty lazy and the lift is kinda low. Those lobes are probably more like a 224/228 after .200 lift and don't even carry lift as high.
lots of the high end cams will get you to your HP goal, but the size of the lobes needed will open the exhaust valve too soon to get amazing tq numbers. To get those you're going to need to pull the heads, mill for compression and flycut, or you'll need better heads all together.
Old 06-09-2008, 07:14 PM
gillbot's Avatar
Dam, I only made 399.xx.
Old 06-09-2008, 07:22 PM
SSlow1's Avatar
I made 391/386 on a Mustang dyno Cam only in a stalled A4. Mods are 3:73's, CAI, full exhaust w/ ORY, Built tranny w/ Vig.3200 stall, and a RPM2 cam
(232/234 595/598 on a 112) I should be around 410+/- on a dynojet.
Old 06-09-2008, 09:40 PM
corvet786c's Avatar
I made 397rwhp 374 trq on a dynojet cam is 222/228/115 with full bolt on's and drivability is great, car just keeps pulling up top.
Old 06-09-2008, 10:13 PM
ABQ99TA's Avatar
I think your HP# is doable cam only but to have 4+ hp/tq cam only is going to be tough.
I agree with milling to bump comp. and hope for more tq but 4+ I don't know. I put 404rwhp and 374rwtq with cats on after market rims that are a little heavy. The car could have done maybe 410+ with no cats and stock rims but the TQ I'm sure would have never gone past 380-385. My cam is the TSP Torquer 3
Old 06-09-2008, 10:31 PM
LT1Formula007's Avatar
Them are some pretty stout numbers guys!
Good luck with hitting 400+ hp/tq.
James
Old 06-09-2008, 10:37 PM
cowboysfan's Avatar
well! 2001 WS6 M6, Comp Cam 231/237 .589/.595 112+4 lsa 112, cnc LS6 Patriot Perf 59cc 2.02in/1.87 ex, kooks Lt, x-pipe, bullets dumped no cats, ported TB, stock intake (ls6), Granatellis' maf sensor, SLP lid, K&N filter. 418rwhp/389rwtq..... mustang dyno.............
Old 06-09-2008, 10:50 PM
DTB_LS1's Avatar
I just put down 402 rwhp and 374 rwtq in my 2000 M6 SS with Speed Inc. SI5 cam using a Fast/NW intake setup. These numbers are also through a heavy drivetrain that includes an LS7 clutch and a 9"w/3.89 gears. The rest of my mods are in my sig.
Old 06-09-2008, 11:34 PM
JBIRD02's Avatar
I put down 393hp/383tq on the old tune w/ an ASA cam (226/236 .525 110lsa).
No #'s w/ the new tune, but I picked up 3 tenths and 4mph @ the track, so I'm assuming I'm in the neighborhood of 400hp now.
Old 06-10-2008, 04:46 AM
so which cam out there will get me to where i want then? i am already going forged internals so i dont have to worry about fly cutting...and i am looking at stage 3 ported 241 heads ...flow really really well..
Old 06-10-2008, 05:36 AM
blackonblack02_Z's Avatar
I am running an MS4 in my M6 car. I have a ported TB, underdrives, FTRA, and MSD wires. I made 434 RWHP on a Dynojet dyno, With a 9in witch eats some power. I say go with an MS4, I have had no problems with it driveable wise and it sounds mean as hell!
Old 06-10-2008, 06:43 AM
chrs1313's Avatar
dyno numbers and times in signature have about 3 threads out there on the cam and setup...was dynoed at speed inc
With ls6 intake and being an A4...
Quick Reply: 400+ cam only cars!!!
