Convertible Vehicles Enthusiasts | Information | Maintenance
Driveshaft Loop Help
Old 03-08-2005 | 10:17 AM
AnotherScreenName's Avatar
Question Driveshaft Loop Help
Anyone reccommend one that fits a convertible?
Edit: Its an '01 Camaro. Single 3" exhaust.
Old 03-08-2005 | 10:34 AM
Found in drag racing forum:
Lakewood.
Also Jegs with some drilling.
(For future searches)
Old 03-10-2005 | 12:05 PM
bc56f100's Avatar
Ive got the spaun torque arm and it has a loop on it. I would definitly recommend the torque arm. If you dont have an aftermarket one you will be very supprised in the results.
Billy
Old 03-14-2005 | 08:23 AM
brandonppr's Avatar
Check my sig.
also I don't think the lakewood will fit the vert.
Old 03-16-2005 | 07:55 PM
Originally Posted by brandonppr
Check my sig.
Doesn't specifically say which ones will fit a convertible, only those that don't.
Old 03-16-2005 | 09:52 PM
DaveSchott's Avatar
I use the Jegs on my vert, required 4 holes but it mounted in a good spot. I have a spohn arm w/o the loop so couldn't use a bolt-on to the cross brace.
Old 03-17-2005 | 03:35 PM
SSpeedracer's Avatar
I use a lakewood along with several other convertible owners. I tried a LG unit but it did not fit.
Helps that lakewood is one of the least expensive.
Old 03-21-2005 | 04:49 PM
Ragtop 99's Avatar
A couple years back I tested a couple of them and would fit on my car w/o modification
Old 04-01-2005 | 01:47 PM
Did you mean to say "NONE" would fit without modification?
Old 04-02-2005 | 08:32 PM
PRAY HRD's Avatar
i just removed a BMR d/s loop from my vert and it doesn't look like there was any modifications made to fit it. if you're interested, i'll let it go for $50 shipped. looks great, is black, and was only on the car for about 3000 miles max. take a look on BMR's site and pm me if you're interested. Speed Inc. installed it with a bunch of other things so that's why i say it doesn't look like anything was done to make it fit. you can call BMR too and just ask them if you want. let me know when you get around to it if you are interested.
later,
Dave
Old 04-05-2005 | 12:27 PM
later,
Dave
Thanks for the offer. I will keep it in mind and research it a bit. I am, right now, leaning towards the spohn TA with loop.
Old 04-05-2005 | 03:31 PM
jimmyblue's Avatar
I can tell you for a fact the Lakewood fits a 'vert.
You also don't have to detach the driveshaft to
install it.
Old 04-12-2005 | 11:47 AM
HOSS99's Avatar
The SLP Drive Shaft Loop fits Convertibles. I have one on my 'vert.
Old 04-13-2005 | 08:18 PM
Ragtop 99's Avatar
DOH! Yup, none fit w/o modding them.
Old 04-14-2005 | 12:09 AM
ACW's Avatar
ACW
Thread from 2003 also says SLP's works https://ls1tech.com/forums/convertible-vehicles/117378-vert-drive-shaft-safety-loop.html (Don't know if they're talking about with modifying it or not.)
Old 04-14-2005 | 12:51 AM
indyparts's Avatar
Got mine off of Jegs... $24 I believe... Very strong
Old 04-14-2005 | 07:55 AM
HOSS99's Avatar
No Modifications were made to my SLP DSL to fit make it fit my 'vert.
