Chemical Guys Paint Correction Is Clutch for Restoring Your Ride’s Finish
Need to correct and perfect your LS project’s paint? Chemical Guys’ C4 Clear Cut and P4 Paint Perfection are ready to tackle the job.
There’s nothing worse than the paint on your LS- or LT-powered project not looking its best. From the bright sun to trips to the car wash, sooner or later, you may find a scratch or two on that otherwise stunning paint job. The only way to fix this, of course, is through paint correction, a process which some feel belongs in the hands and tools of a professional.
Chemical Guys, though, believes you can correct your ride’s paint right at home. To enable this, they’ve introduced two new products: C4 Clear Cut Correction Compound, and P4 Precision Paint Perfection Polish.
“Paint correction has long been an intimidating part of the auto detailing process. Especially for someone that has never navigated a sea of compounds, glazes, polishes and pads,” said Chemical Guys CRO, John Mansfield. “That makes the launch of C4 and P4 exciting, considering this pairing, combined with instructional videos on the Chemical Guys YouTube channel, offers an easy-to-understand approach allowing anyone to take on improving minor imperfections without removing paint or clear coat.”
The first ingredient of this pairing is the C4 Clear Cut Correction Compound. This alone brings out the sparkle lost through oxidation, swirls, and other maladies. The non-dusting formula behind C4 means a smoother, more even cut through the clutter made easier and faster than other correction compounds. Just apply to your rotary or DA polisher, spend some time, and that Firebird of yours will truly be fire.
If your paint needs more oomph after the C4, though, the P4 Precision Paint Perfection Polish is there to bring your GTO’s paint to the finish line. The lightest of swirls and finest of sanding marks are no match for this polish. By the time you put away the polisher, you’ll have a reflection better than a mirror. You can also use P4 by itself for light defects before the car show.
Want to see more? Have a look at this Hyundai as it gets double-teamed by C4 and P4. After that, you can head over to chemicalguys.com or your nearest Detail Garage. Drop a $20 for each product, then make your Camaro’s paint pop like never before.
