TVS2300 Blown Firebird Formula Lays Down 719 hp and 678 lb-ft: Video Inside
Sure you still have to trim the cowl for clearance, but in return you’re rewarded with gobs of torque, as proved by “Sally.” She’s a Formula Firebird with the heart of a 6.0 LQ4 motor with AFR 225 heads, a custom blower camshaft, a Magnuson TVS 2300 blower and a Nick Williams 102mm throttle body. All that twist travels through a Level II T56 transmission, a Ram Powergrip HD clutch and into a Hawks 8.8 rear-end before reaching the ground to the tune of 719 hp and 678 lb-ft. The 700+ horsepower figure is impressive, but the diesel like torque peak with an equally flat torque curve brings new meaning to the term, “Tire Frier!”
Have a look at the build and listen to it scream on the dyno!
Follow the link for more info HERE.
