Should be faster...12.8 at 109
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
MODS:
full weight minus air/egr system/pump
plus two 12s in rear...i only 109 thou
228r cam
ls7 lifters
double springs
hardened push rods
3200 stall
3.73 gears
built 02 trans
stock susp.
street tires=13.0 @109 after cam-spinning
nittos=12.8 @109 before cam
strut bar
ls6 intake
slp lid/maf
tune by frost
pp tb
knn filter
long tubes
hooker catback
resonators-cats
think thats it
I ran a 12.8 @109 before cam dynoed at 335/336
dynoed at 335-336 before cam/stall/gears/pp tb, out of slp lm1
Ran 13.0 @109 after cam on street tires spinning ...dynoed at 376/350 all mods besides hooker catback/strut bar...may be higher dyno isnt running right
9/30/08 NOTE Car redynoed after dyno fixed on the 27th and made 364/343
I am told my mph is low...should I be low 12s high 11s ...i no i am spinning but the street tires are pretty good and i c other do it so y cant i darn it...
Suggestions:
I no I need to install my sfc and get lca relocation brakets and of course mt..
but what can i do to leave the setup the way it is and get higher mph/lower 1/4 or can I not do that
228r cam
ls7 lifters
double springs
hardened push rods
3200 stall
3.73 gears
built 02 trans
stock susp.
strut bar
ls6 intake
slp lid/maf
tune by frost
pp tb
knn filter
long tubes
hooker catback
resonators-cats
think thats it
Suggestions:
i still spun some on nittos...so i no i need tires
i was told to get lca rel. brck but havent had a chance yet
i just dont see spinning effecting the 1/4 mph/time as much as it does...i could be wrong thou
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
okay ill get my slips tonight and post what they say... i no my 60 was 1.8-1.9 before cam on nittos...but with cam and street tires...2.2ish... will varify on slips tonight
for lca relo brackets... yes, they aren't just for lowered f-bodies. they will change the center of gravity for stock height f-bodies. i've been meaning on getting myself a set too. i have the same problem your having, but in a M6 car. I of course give an easy launch, but am hitting low 13s at 109+ mph
spining does effect your ETs. an old-timer once told me than for every wheel rotating of loss traction is a tenth off your time slip.
and i am not running nos
I do not have a run on dr with cam...dr i had sucked...not to say street tires did any better...
All mods:
84 degrees outside
8/8/8 street tires...all mods
r/t .137
60' 2.056
1/8 8.539
mph 86.12
1/4 13.070
mph 109.40
Drag(nitto) No cam with stall /gears...ect
7/6/8
.590
1.928
8.353
83.99
12.993
106.74
.422
1.932
8.298
84.54
12.912
107.32
.097
1.936
8.291
84.65
12.896
107.54
.138
1.958
8.347
84.33
12.968
107.26
.089
1.932
8.318
84.33
12.939
107.18
.168
1.949
8.320
12.938
107.22
5/9/8
.264
1.904
8.299
83.84
12.945
106.36
.432
1.939
8.331
84.04
12.968
106.69
above runs were dinn. track
below is richmond
.1083
1.9808
8.3214
84.89
12.9351
107.37
.6482
1.8935
8.3154
83.99
12.9741
106.74
All mods:
84 degrees outside
r/t .137
60' 2.056
1/8 8.539
mph 86.12
1/4 13.070
mph 109.40
7/6/8
.590
1.928
8.353
83.99
12.993
106.74
.422
1.932
8.298
84.54
12.912
107.32
.097
1.936
8.291
84.65
12.896
107.54
.138
1.958
8.347
84.33
12.968
107.26
.089
1.932
8.318
84.33
12.939
107.18
.168
1.949
8.320
12.938
107.22
5/9/8
.264
1.904
8.299
83.84
12.945
106.36
.432
1.939
8.331
84.04
12.968
106.69
below is richmond
.1083
1.9808
8.3214
84.89
12.9351
107.37
.6482
1.8935
8.3154
83.99
12.9741
106.74
Well you are consistent. Those 60s and 1/8th mile time are hurting you for sure. The only way to get around those needed mods would be to throw some slick on and see what happens. I dont think you will brake anything with a 3200 stall but maybe some ET Streets for starters. Your not shifting manually are you?
