For honing a LS1 block, which stone/grit is good for steel nitrate rings?
I've read that the ls1 blocks require a finer or softer stone because of the liners and newer rings versus the old school SBC blocks. I'm using Mahle's upgraded steel nitro rings, and curious what I should be telling the machine shop. Anyone that works at a machine shop or has actually used these rings have any input?
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
You need to get surface finish spec for the rings, then have the machine shop use the necessary stones and procedure to meet that number. But otherwise I would agree with the final 400/plateau
Originally Posted by thesoundandthefury
Heyyyyyy it's M-1.
Glad to see you over here. ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by 2002_Z28_Six_Speed
Does plataeued mean you are sort of very slightly countersinking the steel liner at the top of the bore?
It depends on who's honing and what they are honing with. I hone with all the fasteners and the mains torqued and with the same gaskets and torque plates with again matching fasteners. I charge 150.00 for a block we are honing .010 or less and 225.00 when I also have to take it out to a much larger size and hone it to final size. We use a CK10 Sunnen and if possible you want to stay with a Sunnen Hone or at least one of teh newer Rottlers. Most other hones will not get you as round as fast.
6600 rpm clutch dump of death Administrator
http://www.automotiverebuilder.com/ar/eb010642.htm
High Performance Piston Rings and Cylinder Finishes
by Larry Carley, Technical Editor
lcarley@babcox.com
Today's performance ring sets are thinner, lighter and more conformable than ever before. Thinner, low-tension rings reduce friction for more usable horsepower. Less weight reduces ring groove pound out. Narrower rings also allow tighter tolerances and less blowby. All very good things when you're building a performance engine. But they also require rounder, straighter cylinder bores than ever before.
Though many racers are running 1 mm compression rings, some ring manufacturers are selling compression rings as narrow as 0.6 mm. At the recent Performance Racing Industry show in Orlando, FL, one manufacturer showed us a one-piece 1.5 mm oil ring. The company said the super narrow oil ring is being used in some NASCAR NEXTEL Cup Series engines and is not yet available to the general public. The reason why the rings are being limited to NEXTEL Cup racing is because they are tricky to install and require a zero clearance end gap. These rings are not a true "gapless" design because the ends of the ring just butt up flat against each other.
Another reason for the smaller rings in many performance engines is that pistons are getting shorter. Longer connecting rods with shorter pistons change the combustion dynamics and provide better angularity during the power stroke. Shorter pistons also weigh less, which means the engine can rev higher. But when the piston is shorter, the rings have to move up higher. This means they have to be narrower, stronger and more heat resistant because the top ring is closer to the combustion chamber.
Cast iron piston rings are still a popular choice for dirt track claimer motors as well as many street performance and other racing applications. But cast iron is not in the same league as ductile iron or steel rings when it comes to strength. Ductile iron rings have roughly twice the tensile strength of grey cast iron, and three times the fatigue strength. Steel rings, by comparison, have almost four times the tensile strength and fatigue strength of grey cast iron.
So what does this mean inside an engine? It means ductile iron and steel rings can survive in racing environments that may be too demanding for grey cast iron rings. Stronger rings reduce the risk of ring breakage under severe loads. Steel rings also show less side wear and ring groove pound out.
For high boost turbocharged and supercharged engines, and engines using large doses of nitrous oxide to add horsepower, ductile iron or steel top rings are probably a must. Many racers prefer to use nitrided rings made from steel wire because the rings can handle high loads and thermal shock better than other materials. Nitriding penetrates into the metal and won't flake off like other surface coatings.
Plain uncoated grey cast iron rings are inexpensive and are popular for "budget" motors. But plain cast iron rings should never be used in an engine that burns alcohol because alcohol cuts lubricity. Some type of coated rings must be used with alcohol.
Moly is still the most popular facing material for many piston rings because of its excellent wear and scuff resistance. Another material is tungsten carbide (for hard liners), and chrome. Chrome-faced rings are still a good choice for abrasive environments like dirt tracks, and work best with cast iron blocks and cylinder liners. Chrome rings don't work well with chrome plated bores or hard faced cylinder bore liners such as those coated with nickel/carbide coatings.
Hard Liners
The practice of coating cylinders with nickel and silicone carbide (the best known name is Nikasil, which is a registered trademark of Mahle Gesellschaft) got its start in Formula 1 racing, and is now used in many different levels of racing from circle track to drag racing to motorcycles.
The hard ceramic facing inside the liner is a mixture of nickel and silicon carbide that is only about 0.07 mm (.0025" to .003") thick. Small particles of silicon carbide less than 4 microns in size are dispersed throughout the nickel matrix. The result is a very hard and wear resistant surface that reduces friction and allows the engine to develop more horsepower. The surface has a hardness of about 90 HRc.
The liners are also dimensionally stable and experience less bore distortion than ordinary cylinders, which reduces blowby and leak down (some claim less than 1 percent after extended use). But to seal properly, these liners require two things: moly or tungsten carbide faced rings, and a very smooth bore finish.
The surface of a liner with this coating has microscopic pores that do an excellent job of retaining oil for the rings. Consequently, the bore can be finished to a super smooth finish of 4 to 6 Ra or less to reduce friction even more. Such low numbers would be too smooth for grey cast iron and would likely starve the rings for proper lubrication. Chrome plated bores or liners, by comparison, can also provide good lubrication while reducing friction and wear, but chrome is more vulnerable to dirt scoring and there may be some risk of flaking.
Bore Finish
Regardless of what kind of rings or liners are used in a performance motor, rings usually seat best and last the longest when the cylinder bores are given a plateau finish. A plateau finish essentially duplicates a "broken-in" bore finish, so there is less scrubbing and wear on the rings when the engine is assembled. What's more, if the surface is finished correctly it will provide plenty of flat, smooth bearing surfaces to support the rings while also retaining oil in the crosshatch valleys to lubricate the rings.
The only exception to this is in motors where there is a lot of bore distortion. If the bores go out of round when the head bolts are torqued down, the rings may not seat as well allowing increased blowby and oil consumption. Thinner rings that can conform to the bore will work better in these kinds of applications, but it's also a good idea to use torque plates when honing when honing the bores to simulate the distortion that occurs when the cylinder heads are installed. The other option is to go with a slightly rougher "peaked" finish to seat the rings.
Most ring manufacturers recommend using a two- or three-step honing procedure to achieve a plateau finish. First, rough hone to within .003" of final bore size to leave enough undisturbed metal for finish honing. For plain cast iron or chrome rings in a stock, street performance or dirt track motor, hone with #220 grit silicon carbide stones (or #280 to #400 diamond stones) to within .0005" of final size. Then finish the bores with a few strokes using an abrasive nylon bristle plateau honing tool, cork stones or a flexible abrasive brush.
For moly faced rings in a street performance, drag or circle track motor, hone with a conventional #280 grit silicon carbide vitrified abrasive, then finish by briefly honing to final size with a #400 grit vitrified stone or #600 grit diamond stone (or higher), plateau honing tool, cork stones or a brush.
For stock and street performance engines with moly rings, an average surface finish of 15 to 20 Ra is typically recommended. For higher classes of racing, you can go a little smoother, provided you don't glaze the cylinders.
For moly or nitrided rings in a performance motor, hone with #320 or #400 vitrified stones, and finish with #600 stones, cork stones, a plateau honing tool or brush.
If the cylinders are rough honedwith diamond, they can be finish honed with a finer grit diamond, a fine-grit vitrified abrasive or a plateau honing tool or brush. Because diamond is a harder material and wears more slowly than conventional abrasives, it cuts differently and may require more honing pressure. But many newer diamond stones now use a more friable bond that stays sharp and doesn't load up, allowing the stones to cut smoother and leave a rounder, smoother bore finish.
When using diamond-honing stones instead of vitrified abrasives, you generally have to use a higher number grit to achieve the same Ra (roughness average) surface finish. For example, if you have been using #220 grit conventional stones to finish cylinders for plain cast iron or chrome rings, the equivalent diamond stones might be a #280 to #325 grit. If you have been using #280 grit conventional stones to hone for moly rings, the diamond equivalent might be #400 to #550 grit stones. The actual numbers will vary somewhat depending on the brand and grade of the stones.
Bristle style soft hones (plateau honing tools) have mono-filament strands that are extrude molded with a fine abrasive material embedded in the strands. The filaments are mounted in different types of holders for use with portable or automatic honing equipment. Another type of brush uses molded abrasive ***** that are mounted on flexible metal shafts so the ***** can easily conform to the surface. Brushing helps sweep away torn and folded metal on the surface while removing many of the sharp peaks to make the surface smoother.
lcarley@babcox.com
Hard Liners
Bore Finish
When finishing the cylinders with a brush, only light pressure is required. The rpm of the brush should be similar to that which the cylinder was originally honed, and no more than 16 to 18 strokes should be applied (some say 8 to 10 strokes is about right). Too many strokes with a brush may produce too smooth a finish in a cast iron cylinder that won't retain oil. Reversing the direction of rotation while brushing helps to remove the unwanted material on the surface. The end result should be a cylinder that provides immediate ring seal with little if any wear on the cylinder wall or rings when the engine is first started.
With the right plateau honing techniques, you should be able to get the surface down to an average roughness of 8 to 12 Ra or less, with RPK (relative peak height) numbers in the 5 to 15 range, and RVK (relative valley depth) numbers in the 15 to 30 range. These numbers are meaningless unless you have a surface profilometer that can measure them (which a growing number of performance shops now have).
Crosshatch
Crosshatch is also important because the amount, depth and angle of the crosshatch in the cylinder bores determines how much lubrication the rings receive and the rate of ring rotation.
Excessive shallow crosshatch angles can hinder or slow down the necessary ring rotation that allows the rings to dissipate heat. It can also leave too much oil on the cylinder wall allowing the rings to skate over the surface and the engine to use oil. Too steep of a crosshatch angle may not provide enough oil retention and can result in dry starts and premature ring wear. A steep crosshatch angle can also create excessive ring rotation that accelerates ring and piston groove wear.
Ring manufacturers typically recommend a crosshatch angle of 22° to 32° as measured from horizontal and uniform in both directions.
Bore Geometry
Bore geometry is especially important in performance engines because of the higher cylinder pressures they generate and the higher rpms at which they operate. Torque plate honing is a must with all performance engines to compensate for the bore distortion that occurs when the heads are installed.
Typically, cylinder bores tend to squash in and deform the most in areas that are next to the head bolts. Depending on how many head bolts are around the cylinder (four, five or six), the bore will experience fourth, fifth or sixth orders of distortion. Oblong distortion may also occur from side loading during the honing process.
The cylinders should be round and straight to a tolerance of .0005" (0.13 mm) or less (ideally, .0002" to .0003").
Bore distortions are bad at high rpm because it can prevent the rings from conforming to the surface, allowing more blowby and oil consumption. If the cylinders are not straight, the rings can bounce away from the surface and lose their seal with the same results.
The amount of bore distortion that occurs depends on the block, the location of the cylinders, and the design of the heads and how much loading is on the head bolts. The higher the bolt loads and the less rigid the block, the more distortion that occurs in the bores.
At the PRI show, C-K Engineering Inc. of Baldwin, MO showed a new Cylinder Bore Geometry Gauge that can measure and display bore distortion graphically on a computer. The drawing that results is three-dimensional and color coded to show the areas of greatest distortion. The gauge system is claimed to be accurate down to 1.0 micron (.000040")!
Hot Honing
Hot honing got its start back in the late 1950s and early 1960s when legendary engine builders such as Smokey Yunick and Bill Jenkins experimented with a hot honing process to achieve rounder cylinder bores. The idea was to hone the engine hot (at 200° F) to simulate the bore distortion that occurs when the engine is running. Over the years, various racers have experimented with the process and today a majority of NASCAR engines are hot honed.
Hot honing holds the most promise for endurance engines that run at high rpm for long races (like NASCAR and off-road racing). But it provides less of a benefit for drag racing and street engines. Even so, some Pro Stock drag racers are now hot honing their blocks.
In terms of friction reduction, hot honing is claimed to offer a 1 to 2 percent improvement, which is good for maybe 5- or 6-hp in a 600-hp engine. Tests have shown that some bores can distort as much as .0035" at 220° F compared to room temperature. Less bore distortion when the engine is hot means better sealing and less blowby. The numbers are not huge, but in tightly regulated racing classes every advantage helps.
Several companies now offer equipment that allows cylinder blocks to be honed hot. The equipment typically has a pump and heating unit to circulate hot coolant through the block. The process doesn't totally duplicate a running engine because there is no way (yet) to make the top of the cylinder hotter to simulate the heat effects of combustion. Even so, hot honing will produce rounder, straighter bores in a running engine than honing at room temperature. Just keep in mind that the cylinders will distort when they cool down - but will return to a round condition when the engine fires up and runs.
Ring End Gaps
The old school philosophy of engine building said the end gaps on second compression rings could be tighter because the number two ring is not exposed to as much heat as the top ring. The new school of engine building says it's better to open up the second ring gap 20 to 30 percent so pressure doesn't buildup between the rings and cause the top ring to lose its seal at high rpm. The result is better compression, better piston cooling and reduced oil consumption.
Any pressure that builds up between the rings will blow down into the crankcase, keeping oil out from between the rings. This trick works best on engines that are running a dry oil sump and pull a vacuum in the crankcase.
Some performance pistons also have "accumulator grooves" machined into the piston land between the first and second ring grooves. The added space traps blowby gasses and helps prevent the top ring from unseating and fluttering.
For naturally aspirated engines, a top ring end gap of .004" per inch of bore diameter is often recommended for a stock or moderate performance engine. For a 4-inch bore, that translates into a top ring end gap of .016" to .018". But this will vary depending on the power output of the engine.
For drag or oval track racing, the recommended end gap is somewhat larger (.0045" per inch of bore diameter). With four-inch bores, that would be an end gap of .018" to .020".
For a nitrous oxide street performance engine, the recommended end gap is .005" per inch of bore diameter (.020" to .022" for an engine with four-inch bores). For a nitrous oxide drag engine, the recommended end gap for the top ring is .007" per inch of bore diameter (.028" to .030" with four-inch bores).
With a turbocharged or supercharged racing engine, the top ring gap should be .006" per inch of bore diameter (.024" to .026" with a four-inch bore).
The recommended end gaps for second compression rings are also the same, with slightly larger gaps if you want to minimize pressure buildup between the rings.
The recommended ring end gap for most oil rings (except the new super narrow one-piece rings) regardless of engine application is typically .015".
Another trick to improve ring sealing at high rpm is to run pistons that have gas ports behind the top ring. Combustion pressure blows through the port to help seal the ring from behind and underneath. Some use vertical gas ports with holes drilled from the top of the piston to the top ring groove just behind the ring. Others use lateral gas ports that are drilled through the bottom side of the top land and extend to the back wall of the ring groove. Gas ports work best at high rpm (above 7,000 rpm) and are not recommended for street engines.
Getting rid of the end gap altogether can also improve sealing, cooling and horsepower. Gapless rings eliminate the gap between the ends of the ring by overlapping slightly. Gapless rings are available in popular sizes with various wear-resistant face and side coatings. Some engine builders who have switched to "gapless" top or second compression rings say they've gained three to five percent more horsepower with no other changes. Gapless rings are said to allow less than 1 cubic feet per minute (CFM) of blowby and on alcohol-fueled engines, a gapless top ring or second ring helps keep alcohol out of the crankcase.
Crosshatch
Bore Geometry
Hot Honing
Ring End Gaps
Originally Posted by MiaSSmaro98
yeah but i heard u cant really open them up to much on the 98 blocks so wat size should i get
Another good article on rings...
http://www.circletrack.com/techartic...ent/index.html
Piston Ring Tech - Ringing Up New Power
Often Overlooked, New Piston Ring Technology Can Help Engine Builders Find More Horsepower At Every Level Of Racing
By Keith Dorton
Photography: The Circle Track Archives
For years piston rings were paid little attention by either racers or engine builders. They are small, fairly straightforward and on the surface would seem to have little to contribute toward finding horsepower. But that’s a big mistake to make. Over a decade ago ring technology took a big evolutionary step that really contributed to power and engine durability, and I think stage two of the evolution is taking place right now.
The first time I was aware of people in the oval-track business really starting to pay attention to piston rings was somewhere around 1989-90. Really, the only reason was because we started having problems with them. It was about this time that we started pulling vacuum with the oil pump into the engine and learned that we could lessen tension on things like oil rings, pull some vacuum and increase power. In doing this you had a tendency to dry up the cylinder, which created a problem called micro-welding. That’s where the piston actually transfers metal and bonds itself to the top ring. When that happens it’s usually catastrophic—you lose all seal and start scuffing the cylinder.
While this was happening, a major manufacturer made a manufacturing change that none of us knew about. The change was supposed to be for the better, but it really introduced an inconsistency in the face of the ring (the surface that comes in contact with the cylinder).
The standard for quite some time has been moly-faced rings, and that’s what we were using then. Normally, the ring has a channel machined into it, the moly filler is sprayed into it, and then it’s ground to its finished size. There were some inconsistencies in the way this moly was applied, which created some sealing problems in addition to the problem with micro-welding. So, for quite a period of time between ’89 and ’90, it seemed we were either micro-welding rings or not getting a good seal.
So myself—and just about everybody else in the business at that time—started paying a lot of attention to piston rings where we were taking them for granted before. It became part of our build-up process at Automotive Specialists to examine every top ring all 360 degrees around under 40 power magnification. It was very costly, very time consuming and we were rejecting somewhere between 70 to 80 percent of the rings. Thankfully, the manufacturer recognized the problem and corrected it, but it took a while.
The changes that were made really helped increase the dependability of the rings, which in turn upped the durability of the race engines we were building. Now, as we learn more about what is going on inside the engine, the advances we are making are really helping out power—both in terms of reducing friction and creating more horsepower by increasing efficiencies in the combustion chamber.
Properly preparing the cylinder is an important step and an area where I feel we can still realize big gains. Every engine builder worth his salt knows the importance of using a torque plate and having the main caps torqued in place to simulate the stresses on the engine once it’s bolted together. People have been doing that for years. The next step is to really zero in on cylinder wall finishes for given variables and needs. At Automotive Specialists we’ve looked at different types of finishes on the cylinder wall to change the Rpk and Ra values (for roughness). We’ve found ways to produce a deeper valley in the crosshatch pattern but still have a smooth finish. This improves oil retention on the cylinder wall without increasing friction as the ring makes contact with the cylinder wall. We’ve been working with a ring company and a piston company on this project, and their engineers have been very helpful. I don’t mean to be an advertisement for anyone, but Total Seal and Mahle Motorsports, the companies we’ve been working with, have made some advancements in ring technology I’m sure you are going to want to know about.
The ring manufacturers have been using profilometers for years to measure Rpk and Ra (surface roughness of materials). We don’t even have one yet, but I believe the time is soon coming when it’s going to be a necessary piece of equipment in every engine builder’s shop. The profilometer has shown us that different alloys used in different engine blocks—say a production GM block to an aftermarket block—will respond better to different honing patterns. That’s not to say that the same honing procedure won’t work, but I’m convinced that there are some advantages to be had by varying the process depending on the material, its hardness, alloy content and some other things. Ring seal has become a science in itself. If you want to take that next step in power, it’s something engine builders are going to have to be aware of.
In the near future I think we will start seeing—where it’s legal—different types of cylinder wall liners. The Nikisil liner has been around for a few years, and I think you are going to see similar things involved in our industry. There are a number of processes in the works now that I think are going to make liners more practical and affordable for the average racer. Even today, aluminum block engines have a sleeve you can remove and replace pretty readily, so we may see that in those types of engines first. I can definitely see somebody within the industry offering a piston/ring/cylinder package that will be worth some power. It’s probably already taking place in Formula 1, but the way things are going I don’t think it will be too long before it’s available—and affordable—all the way down to maybe the touring series level.
So what does this have to do with the Saturday-night racer? Plenty.
Manufacturers are able to hold both pistons and rings to much tighter tolerances, so simply doing a good job of cylinder preparation—good, straight, round cylinders—is going to produce power. On top of that, ring manufacturers are very free with the knowledge they are gaining in honing procedures, and they are usually very willing to teach you what they spent a lot of money and effort to discover.
A lot of the gains these days are coming from improved fit between the ring and the piston. This is a result of both ring and piston manufacturers learning how to produce their products to tighter tolerances. The CNC technology available today makes it possible for the ring lands to be exceptionally flat, almost zero variation all the way around, which is absolutely critical. That contributed to a lot of the problems we were having years ago, but we didn’t realize it. It used to be only the Winston Cup teams could afford the processes it took to create nearly perfect pistons, but that technology is beginning to trickle down and you can find that level of perfection on some pistons marketed to the Saturday-night racer. One of the companies we have found producing pistons with exceptionally flat ring lands is Mahle Motorsports. Again, I don’t mean to be an advertiser for anyone; I’m just trying to pass on some of the things I’ve learned.
I believe engine builders have contributed to the problems with uneven ring lands by machining on the pistons after we got them. The piston manufacturers have found out that the ring groove needs to be the last machining operation performed on the piston. If we get a piston and it’s got perfectly flat ring grooves, then we mock the engine up and realize we need another .080 valve clearance, we’re going to put that thing in a chuck and cut that .080 out of the valve relief. There’s a chance we’ve just done some damage to the ring groove. You are generating heat that’s inconsistent with what the piston is going to see in the engine, and I’m sure that machining it contributes to some of the inconsistencies in the ring grooves.
I can’t speak for other engine builders, and the only thing we take to the bank is what we know for ourselves, but on a 570hp engine I’ve seen gains of six to eight hp with absolutely no other change other than switching out the piston/ring package. It was just improved ring seal: lower tolerance rings, precise ring grooves in the pistons and us not screwing around with the pistons after we got them. Even when I was assembling the short block it was obvious that it required less force to turn the rotating assembly.
The two big factors when it comes to piston/ring/cylinder wall fit are friction and efficiency. Friction is obvious, and reducing it is absolutely vital on low horsepower engines. Once I was testing a 400hp engine on the dyno. After a couple of pulls I dropped the pan and pulled the heads so I could get the pistons out. I pulled off the second ring, bolted everything back up and ran it on the dyno again. The engine gained five hp right there, so that tells you how much friction just that second ring can generate.
Efficiency is the other factor. On a naturally aspirated engine, you are depending on the vacuum created by the piston travelling to the bottom of the cylinder to pull in the air/fuel charge. The better ring seal you achieve, the more vacuum you are going to pull, and the more air/fuel charge you are going to have available in the combustion space to produce power. It’s that simple. It isn’t a matter of doing anything extravagant, it’s simply a matter of having everything spot on.
By Keith Dorton
A Second Opinion ...
Matt Hartford is an engineer with Total Seal Piston Rings and someone I’ve worked with quite a bit while experimenting with pistons, rings and honing processes. Matt can explain the advances in ring technology better than I ever could, so I asked him to help us out with that topic:
At Total Seal we’ve done a lot of work with Winston Cup and other top teams to develop ring packages with the tightest tolerances possible. The CNC technology out there now allows piston manufacturers to hold their land flatness to within a micron (.000040 of an inch). Old-style rings were only able to hold thickness variation to .0005 or .001. Now, we’ve developed technology to hold ring thickness, parallelism and flatness to plus or minus .000050 to take advantage of the increased flatness of the piston lands. Having a consistent radial thickness (the distance from the ring’s id to its od) is also vital. It takes five separate machines to get our rings to this level, but that’s about all I can tell you.
For engine builders, using a flatter, smoother ring is important because the flatter the ring seals to the piston the more blow-by it can eliminate. Blow-by is wasted efficiency, so the more things you can do to eliminate it the better.
When we’re talking about efficiency, back clearance—the space between the inside of the ring and the piston as the ring sits in the groove—is also important. The less you have the better. Think about it this way: Beginning at top-dead center the intake valve opens, the piston moves down the bore and the negative pressure created in the cylinder draws atmosphere through the carburetor. But before that can happen the negative space above the piston as well as the space between the ring and the piston groove must be filled with the negative pressure. The smaller that space the less time it takes for that area to fill and the piston can start doing its job.
As you move to the compression stroke, as the piston and ring begin compressing the air/fuel charge it also has to compress everything along the sides of the piston down to the top ring and the backspace area between the inside of the ring and the groove. Of course that’s a quench area, so when the spark plug fires nothing in that area burns. It’s wasted energy. So the tighter you can hold the back clearance, the more efficiency you can have on both the intake and compression stroke.
Total Seal’s top-level rings are called “Diamond Finished.” They are held to extremely tight tolerances and can have our proprietary anti-friction coating. We also have a variety of basecoating available to maximize performance depending on the hardness of the material used in the engine block.
An old block that you pull out of a junkyard that people have used in the lower levels of racing for years and years requires a different basecoating on the rings than a Winston Cup block, which is a very hard block. So depending on what the block is, we know what it needs for a ring. Now granted, we don’t tell people what that is—the Cup guys don’t even know what they are getting. They just know it works and they can see the results on the dyno. The rest they leave up to us.
When an engine builder switches from old-style rings to top-level rings, like our Diamond Finished line, we normally see gains in horsepower around three to five percent. No matter what else you are running, tighter ring tolerances are going to help you because you are going to have a higher efficiency on the intake stroke. The whole thing we are looking for on ring seal is how much atmosphere you are able to pull into the engine. Anybody can seal an engine on the compression stroke because you have all that gas pressure behind the ring holding it to the cylinder wall. The trick is getting a good ring seal when the piston is going down and trying to pull all that atmosphere through the carburetor. It doesn’t matter how good your flow numbers are in your head or how much air speed you are getting on the flow bench, if your piston/ring package can’t get good vacuum you are wasting that head’s potential and you aren’t making all the horsepower that’s available.
The Diamond Finished series goes for about $600. This set isn’t cheap, but they are gaining popularity in a lot of different series. For the non-professional racer who doesn’t have the resources to buy a $600 set of rings or $2,000 worth of pistons to take advantage of them, the technology used to create the Diamond Finished series rings has also helped improve the quality of the sportsman-level rings. I would recommend a gapless top ring set. They are going to be moly-faced in either a two- or three-ring setup. Predominately, you are going to see this in a three-ring engine, because now you are getting into a ring set that’s under $200 and this is a racer who probably also isn’t investing in Winston Cup-level pistons, either. An off-the-shelf piston from some of the better manufacturers is a great product for his needs, but it isn’t held to the same tolerances as a Winston Cup piston, so he doesn’t need a $600 set of rings. A good rule of thumb is you should expect to invest in rings about 30 percent of the cost of your pistons. So if you have a $600 set of pistons, you don’t need a $600 set of rings.
Just by switching to a gapless set of top rings you are going to see substantial horsepower gains, probably in the range of three to five percent. That comes both from reducing friction and creating more power. A typical three-ring set of rings costs roughly $130. A gapless top-ring set costs approximately $180, so for $50 more you are going to see around a five percent gain in horsepower. That’s about the cheapest horsepower you are ever going to buy, plus it will make the engine live longer because it’s not putting heat down into the crankcase. That’s something anybody can do.
To make the most of better rings you need to be using the correct honing procedures. Just like with the Winston Cup guys, all you have to do is call your ring manufacturer to get good tech help on the best honing pattern for the block and your rings. I can’t speak for other companies, but no matter what rings you are using the tech guys at Total Seal with try to help you out. Good luck and good racing!
