Ask a Professional Detailer
Last week during a 90+ degree 70%+humidity day, I was having a hell of a time removing the BFWD after approximately a 1 hr cure time (I normally let it cure MUCH longer). I wanted the leave it on longer, but decided against it since the thin coating that was already on the car was a living nightmare to remove (plus was on an insane time deadline from my client). I've never had an experience like this with BFWD, even on humid day. I'm working in my 2.5 car garage FWIW.
I'm thinking that next time I apply BFWD, I'm going to do it at night when temps/humidity levels are low and let it cure 24 hours like I normally do.
Rare,
Were you using a new bottle of BFWD? If so I'm wondering if you got a bad bottle. How are you applying it?
. . . .'13 Plum Crazy Challenger (if it matters)
IMO since the car is new, is the best time to correct the paint. Use proper washing and drying techniques and your car should look great for a long time. I bet that car is amazing, I love that color.
Polishes have different levels of abrasives. Depending on what condition paint is in and how hard/soft it is will dictate what polish and pad you use. I have no experience with newer Chrysler paint so I can't say if its hard or soft. Maybe Rare has some experience with this.
Which meguiars products are you using and for what? For some things they are some of the best. It just depends on which products.
Curing and hazing are two way different things. You want the sealant to haze, do the finger swipe test, if it passes, then remove it. If it doesn't pass the swipe test, wait a little longer for it to haze over.
Curing is how long the sealant has sat on the paint AFTER being wiped off completely and without being exposed to any sort of water.
And I recall on average the cure time for BFWD for being topped is about 8 hours, from blackfire..
