Ask a Professional Detailer
1. Wash
2. Clay
3. Test spot - Do a test spot with the least aggressive combo. ie UP with a polishing pad or M205 with a polishing pad. M205 offers more correction than UP while UP offers more polishing oils.
4. Compound - Depends on the test spot. Let the paint tell you what it needs.
5. Polish
6. Protect - Your choice of wax or sealant here.
7. Maintain
https://ls1tech.com/forums/appearanc...black-ws6.html
Read up on proper priming of the pad, from Kevin Brown
Don't use an interface pad.
Exactly this.
Car will be garage kept.
The 1LE Camaro comes factory with a flat black vinyl cover over the hood. When wet i see your typical garbage water spots stuck to the vinyl that dont go away with a good wash. When dry there hardly visible if at all. How could I clean that old hard water spots out? Ive read not to wax this part of the car at all which makes since. What do i do?
The paint, possibly the clear coat, has some very very light scratches in it almost like a chick threw her purse on it and it rubbed. I want to keep that mirror brand new paint shine so what is the best way to start off with this? I wash and wax usually with Meguiars Carnuba Wash and Wax Soap or Mothers California Gold (same type of soap) and the. Use a spray way of meguiars black car spray wax. I want to do it right and i like those products and only do my detailing by hand. I dont own buffers or anything of that nature so just by hand. Should I wash, clay bar, polish, wax? If so what kind of soap and polish and wax by meguiars would you recommend?
http://www.detailedimage.com/Ask-a-P...e-finish-care/
In regards to your paint. If you want to stick with all Meguiar's I would pick up a clay kit and the ultimate line. I always recommend this kit to newbies on the Meguiar's forum
http://www.walmart.com/ip/Meguiar-s-...undle/29670206
The only thing I would change is the soap to something that leaves nothing behind. I would recommend their hyperwash from their Detailer line. Also pick up the clay kit.
The quick interior detailer has a light cleaner in it but it will not alter the appearance of the dash. It will leave UV protection behind. You can use this as often as you like. Can be used on all surfaces including leather. I use this as a quick wipe down on my interiors to remove dust and previous protectants.
I will follow up with a protectant. On an F-Body with the angles front glass, natural shine is probably the best to go with so you don't get glare. I apply it with a microfiber applicator. It does have a cleaner as well so it will get better cleaning action with a microfiber versus foam. The microfiber will also knock the shine down a bit.
Once that has sat on the dash for a few minutes, I will follow up with a light buff with a microfiber towel. It will knock the shine down and remove any excess product.
You may need multiple applications of the protectant if the area is very dry.
