Ask a Professional Detailer
Old Aug 10, 2013 | 08:21 PM
  #2401
TEDSgrad's Avatar
Originally Posted by Cheetoh
Nice Car!!! Want to Sell it?
Thanks for the compliment, Cheetoh.
Short Answer= forgettaboutit!
Long Answer= look me up in 2039 (I'll be 78 yrs old and have owned it for the first 50 yrs)
Only way to realize my investment is to drive it! I love taking long trips with it. How should you take care/clean a car on cross-country trips? I'm not into lugging cleaning supplies along. Is there a national registry of detailers for just a wash along the journey?
Here's a few pics of some: when new I drove out to CA from Mpls and drove up and down PCH top to bottom (2 from Santa Barbara and 1 from No. CA), Zion Ntl Park, Key West (couldn't drive any further). The factory paint made it until last year.
Old Aug 10, 2013 | 08:41 PM
  #2402
Cheetoh's Avatar
In 2039 I will be 88, I'm not sure I will want to purchase it then.....
Old Aug 10, 2013 | 08:44 PM
  #2403
LilJayV10's Avatar
Jeff, thanks for all your time and info!
Questions on caring for new paint: 0-2 yr plan.
Car was painted late Feb '13, brought back to heated shop to cure & brought out May 1. No mechanical sanding used on my car! I'm the original owner. Used Spies Hecker - the solvent (81 WA8774) and 3 coats of clear. How hard is this clear?
My body guy advised against buffing for a driver and said that there is enough clear for that in the future, "learn first." I use the two bucket wash, MF, jetseal 109 (mid-May), and wax.
I'm having a hard time keeping up with the birds. I usually catch them, but one or two slight etches have occurred (nobody else sees them, even when I point them out, they think I'm paranoid). For a driver, will I just have to live with this? What's a reasonable expectation for a driver?
I'm beginning to see the value of learning first, before taking away any mil thickness.
I drove out of the dealership in '89, and I know I have better paint now!
I think everyone is like that with their car. We all know where every little spot is. Keeping a driver near perfect is tough. I was actually talking to GoFast about this the other night. I think sometimes I have unrealistic expectations about how nice a car should be.
I have a pretty good idea how you feel about your car. I feel the same way about every car I correct. I want it to look great and stay that way.
If you do decided to have your car corrected I would seriously consider a permanent coating like Opti coat. It basically gives you another layer of clear coat. It's rock hard, doesn't attract dust and makes your car a lot easier to wash. You also don't have to wax the car for three years.
Old Aug 13, 2013 | 10:14 AM
  #2404
TEDSgrad's Avatar
Yeah, I don't exist to serve my car's needs, it serves me! Admitting that I just can't do everything that I should for it (being a driver), is an essential starting point. 24 - 36 hrs can go by before I notice something, just the truth. That's just the nature of life that doesn't revolve around serving my car . That doesn't mean that I give up, however.
I would still like to know the hardness of the H.S. clear. With three coats, I do have some leeway. I know that paint correction should be once, but it would be nice (if I have enough) to do it year 8 and again year 16. Do opti after each and I could last 25 years.
Realistic expectations are huge as satisfaction is a measurement against those expectations.
Old Aug 13, 2013 | 09:45 PM
  #2405
LilJayV10's Avatar
I would try and find a body shop or someone with a paint thickness gauge. The hardness of the paint isn't necessarily as important as how much is there.
Polishing doesn't really remove any clear. You are just burnishing/polishing the clear. A light correction "typically" removes 1 or 2 microns and a heavy correction about 3 microns.
"Most" factory clear coats are around 50 microns. Paint manufacturers suggest no more than 25% removal of the clear before it can cause long term negative side effects. So if you have 50 microns you can safely remove about 12.5 microns. Aftermarket paint jobs typically have a lot thicker clear coats compared to factory.
To give you an idea how thick 50 microns is; a cigarette wrapper is about 25 microns. This shows how little clear coat is being removed even with heavy corrections.
I hope that made sense.
Old Aug 15, 2013 | 02:58 PM
  #2406
TEDSgrad's Avatar
Good info, thanks
Old Sep 3, 2013 | 07:10 AM
  #2407
therealcreeper's Avatar
My bumper is rock chipped beyond belief, I'm going to dab touchup paint in the larger chips and then wetsand the entire bumper to level some of the touchup and also hopefully make the millions of nicks less noticeable.
Just how long does it take to burn through the clear if you are wetsanding properly? I'll be using 2000 to 3000 grit. I know it's an impossible question, but just to get an idea if I wetsanded your average paint in a 6" square, would it take 30 seconds? 2 minutes? 5 minutes?
Thanks!
Old Sep 3, 2013 | 11:34 AM
  #2408
GoFast908Z's Avatar
Thanks!
You can strike through in a few seconds if not done properly. I'd strongly recommend practicing on some junkyard panels before attempting this.
Old Sep 5, 2013 | 11:02 PM
  #2409
why87's Avatar
Gofast, how exactly do you tackle hard water stains on glass?
Old Sep 8, 2013 | 05:58 PM
  #2410
GoFast908Z's Avatar
Personally I like Meguiars D300 on the DA, but if its really bad, CarPro Ceriglass
Old Sep 9, 2013 | 08:54 PM
  #2411
CamaroSS27's Avatar
Finally pulled the trigger!!!
Old Sep 9, 2013 | 10:10 PM
  #2412
GoFast908Z's Avatar
Very nice!
Old Sep 9, 2013 | 10:35 PM
  #2413
LilJayV10's Avatar
And it begins....
Old Sep 27, 2013 | 09:14 AM
  #2414
djfury05's Avatar
If anyone is looking for some badass wax that can't be bought anymore...
https://ls1tech.com/forums/parts-cla...-wax-bnib.html
Old Sep 29, 2013 | 11:01 AM
  #2415
TechCam97's Avatar
The only thing paint-wise on my 2001 Trans Am that is bothering me is my rear hatch. Not the spoiler, that paint looks fine, but the actual hatch. I have milky white spots all over and they get especially bad when it rains. The clear looks like shattered glass as well.
Other than the back hatch the rest of the paint looks like it was cared for. Is this too far gone?
Old Sep 29, 2013 | 11:09 AM
  #2416
LilJayV10's Avatar
That's clear coat failure. Repainting is the only option to fix it unfortunately.
Old Sep 29, 2013 | 11:14 AM
  #2417
TechCam97's Avatar
That's what I figured. It's weird, the rest of the paint looks fine. It's like the previous owner thought it would be too difficult to reach all the areas of the hatch and just waxed and maintained the spoiler and left the hatch paint to fend for itself. Well, off to the body shop it will go!
Old Oct 13, 2013 | 01:27 AM
  #2418
transwiz's Avatar
Sorry to hijack this thread. I bought some meguires #16 paste wax from djfury05 on this forum. I opened it up (It was sealed) and found it was hard in the center and soft all the way around the hard spot. Am I supposed to do something to this or do I use it as is.I was hoping that gofast or somebody could answer this.
I studied these pages and used some of the products that jeff talked about and the results were amazing.Thanks guys for such an informative post
Old Oct 13, 2013 | 01:41 AM
  #2419
GoFast908Z's Avatar
Hmm, first I've heard of one like that...but these were manufactured some time ago....
Heat it up. Put it in a glass bowl with water (not above the top obviously), then put that bowl in a large pot on the stove and bring the temp up slowly until the wax melts. Once its fully liquid, remove it from the water and gently stir it thoroughly. Then allow it to cool and solidify for at least 24hrs. If that doesn't do it, I don't know what will.
Old Oct 13, 2013 | 02:10 AM
  #2420
transwiz's Avatar
Thanks for the reply.YOU ARE THE MAN!!!
