Completed Wire Mod: Tutorial Inside
Old Mar 27, 2007 | 02:42 PM
  #101
2_wacko's Avatar
Can this be done without a right angle drill?
Old Mar 27, 2007 | 03:16 PM
  #102
94blownz281's Avatar
I just did the hood latch mod today. was kinda a pain to open up the hole on the fender on the firewall for me. looks alot better though.
Old Apr 23, 2007 | 10:18 PM
  #103
i have a question bout this mod for my 1994 z28.. 94's only have one connector and i didn't know how to remove the wires from the connector so i cut and spliced them. its alittle late now but as long as they all have good contact i should be fine,correct?
Old Jun 4, 2007 | 02:51 PM
  #104
05 GSXR 1XXX's Avatar
i did the wire mod/egr/and hood latch last night....LOOKS 10X better!
im still thinking if i should do the hole filler or what, and if so (weld,or bondo) hmm?
Old Jun 20, 2007 | 10:09 AM
  #105
JR HAWK 9's Avatar
does anyone know what -ALL- exactly those wires are for and what they control?
Old Jul 8, 2007 | 07:29 PM
  #106
SpdFrk1990's Avatar
I really want to do this mod just scares me having to drill a hole in it. Not sure if I want to or not.
Old Oct 10, 2007 | 01:48 PM
  #107
The Black Mamba's Avatar
Very nicely done.
Old Dec 1, 2007 | 10:09 PM
  #108
fortmyerspolice's Avatar
no pics or link anymore
Old Dec 2, 2007 | 09:11 AM
  #109
2002 Trans Am's Avatar
Where are you guys finding the grommet for the hole? Not having the grommet is the one thing holding me back from doing this.
Old Dec 2, 2007 | 12:38 PM
  #110
Snuffles's Avatar
Most people just take a small piece of rubber hose, slit it down the side and use that.
Old Dec 2, 2007 | 04:00 PM
  #111
LS1SpeedAddict's Avatar
I had the same problem your having when I did it, every store I went to thought I was crazy even electrical supply houses. These guys sell every rubber grommet imaginable. http://search.cableorganizer.com/sea...mmet&view=list
I wouldn't settle for using the rubber hose I can't see how would look as good.
Old Dec 3, 2007 | 07:36 AM
  #112
OreoLt1's Avatar
Any word yet on a "link to the write up" repair?
Old Dec 12, 2007 | 08:40 AM
  #113
Nice web site, thanks for the link. Now I have to go see how big the hole saw is that I have.
Old Jan 7, 2008 | 02:52 AM
  #114
lswon's Avatar
I moved the tutorial to flickr.com and updated the link on the first page. I didn't have time to maintain lswon.com anymore so I closed it down. I apologize for the inconvenience and hope the tutorial helps everyone out.
Old Feb 28, 2008 | 04:22 PM
  #115
fast01z28's Avatar
bringing this back from the dead to give the OP madd props. I accomplished this today and im very pleased with the results.
Old Jun 28, 2008 | 01:05 PM
  #116
smg267's Avatar
Just finished about 20mins ago! The hardest part was getting that damn abs sensor wire. There is a clip inside of the wheel well that is freakin impossible to reach. I used a random peice of thin metal I had in the garage to break the clip off. The only other part that was left out was when you are grounding the wires to the bottom of the turn signal you need to cut some of the black tape away inside of the loom to get more slack. The Grommet to go inside the hole can be found at any home depot or lowes.
Old Aug 20, 2008 | 12:56 AM
  #117
1fstGM's Avatar
Restricted User
Same question here. I noticed on of mine were broken and am wondering what these wires control. I have a 98 and these could possibly be different, but anything helps.
Update. It is the C105 connector I am interested in. I seem to only have a tan and pink wire there. The tan one was broken. Am i suppose to have any other ones there?
Old Sep 4, 2008 | 03:20 PM
  #118
mrburnout81's Avatar
Finally did this today. Very simple. i went to o'reilly's and they have a grommet that works great. there are two gromments in the package, one smaller and another that is 1 3/4. Its a Help! package, Oil Filler Tube Grommet, part number 42301. Hope this helps people who are having issues finding a grommet. The only part that is a bitch is that abs sensor wire holder on the inside of the frame rail, i also took a long piece of metal and broke it off. when i reinstalled i zip tied it to the wire that ran down next to it. Other than that, this is fairly easy to do and well worth it in the looks catagory.
Old Sep 17, 2008 | 09:28 AM
  #119
Big Bird WS6's Avatar
could a person us like a heat shenk grommet so it looked all factory?
Old Jan 4, 2009 | 07:21 PM
  #120
ALTRDTA's Avatar
I did this last night. Thanks for the write up OP. Just a little info though for those that are doing this and think they need special tools. I learned how to de-pin connectors on my neon, and have done it on numerous occasions. All it takes literally is two small flat head screw drivers and then a safety pin... The screw drivers are used to take the plastic cover off that holds the wires in on the back of the clip. And then the safety pin is pushed through the opposite side of where the wires come through... If you are looking at the face of the clip and have the part that latches to the other end of it facing up then the saftey pin goes in the VERY top of each wire pin... I'm sure all this sounds confusing but it's really easy if you start looking at it. Just remember that the wires pull out the BACK of the clip. they do not come out the face. So just mess with it for a little bit and see if you can figure it out. It's not hard at all!
