Torque Management
Old Feb 19, 2006 | 09:58 PM
jessedale98's Avatar
Default Torque Management
Well, im running consisant 12.4 @ 109 with my current set up N/A, i was wondering if i got rid of TM what could i expect to gain? Also, what would be advantages of no TM when im using nitrous?
Old Feb 20, 2006 | 09:17 PM
I guess i thought i would get a little help here.
Old Feb 20, 2006 | 11:29 PM
jimmyblue's Avatar
Moderator
Have you helped yourself whilst waiting? What have
you learned from searching so far?
I don't favor removing TM and think the trans as
stock isn't up to the abuse. For nitrous I think you
should not spray through the shifts and then TM
is no different. If you made it a more sensible torque
reduction, by programming, instead of simply zeroing
things you could have a compromise that works. I
pull out about 40-60 lb-ft through the shift and don't
even feel it.
Old Feb 21, 2006 | 09:33 AM
chrs1313's Avatar
i also kept TM
Old Feb 21, 2006 | 02:09 PM
So , tm is taking about more than 60lbs of tq?
Old Feb 21, 2006 | 07:07 PM
jimmyblue's Avatar
Moderator
If you let it have its way, it will slam timing back to -10
degrees and take a whole lot more than that (trying to
pull 30% or so and overshooting the mark most heinously).
Reducing the amount it takes out, at the delivered torque
-> torque reduction it wants to make, is how to train it
to play nice.
Old Feb 21, 2006 | 07:11 PM
Well, i use nitrous, could TM cause some bad things to happen?
Old Feb 21, 2006 | 07:55 PM
slowpoke96z28's Avatar
torque management will keep you from hurting the tranny as bad as you could without it. leaving it on though, will not hurt anything except your ET and MPH. torque management can command as much as 100% reduction in engine output. its all in the PCM.
Old Feb 21, 2006 | 08:27 PM
So, what tuner to u recomend? Ls1edit,predator,hpp3,HP tuner, ect. What gains could say a low 12 second car see from removing TM?
Old Feb 22, 2006 | 12:43 AM
DOUBT IT's Avatar
I don't want to hijack anyone's thread, but I've been wondering about it too. I'm going to see how long my stock-ish tranny will hold up to my 4000 stall going in soon. I'd like to take out enough TM that it doesn't affect how the stall works, but doesn't overly tax the transmission.
I already have a good shift kit (custom), with 3.73 gears. It shifts really quickly, with almost no lag. It doesn't ever "slide" into gear like it did stock. Gomer is the one who's going to do my converter tune, with HP Tuners. Is there anything I should let him know about TM.
Car is NA, Bolt-On, BTW.
Old Feb 22, 2006 | 01:01 PM
if i'm thinking right, you 'll have to do a little tuning. if not, the pcm will see a high engine speed and low or no tranny input shaft speed and think that something is wrong.
