Gforce Axles Results **VIDEO**
Here is video of my 2007 CTS-V with both driver and passenger Gforce axles. As the video shows, no hop. ![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
http://www.youtube.com/watch?v=QpKFWvowfnU
I was a bit worried on banging gears but with the new axles there is no hop to blow the diff. I just had my diff inspected by the dealership and they say its in great shape.
Are there any confirmed results of one axle on an LS2 other then on a maggied and cammed car?
I hate to brake it to you, but its the technology behind the axle that works. Regardless of the vendor (DSS/HE or Gforce). If you replace one axle with one that is of different size the hop will be eliminated.
I'm guessing to satisfy you there will need to be 50 different LS2 Vs with 50 different mods to verify that it works. Stop being such a hater and support the V. The more vendors we have making products for our cars the better.
I really wish you would grow up.
Sorry I didn't answer you on the CF...I have you on my ignore list. Mostly due to retarded questions like this one. We all know you are a big HE fan, and that's cool.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Never once have I said that Gforce makes a bad product. In fact we have spoken through PM (information you are not privy to remember?) and I told them I'm sure they make a GREAT product. I am just still trying to understand their reasoning for doing the pass axle rather then driver side when there was already a proven combo that worked. Just trying to learn a little about IRS drive lines.
Also, I have ONE product from Hendrix (which I paid FULL price for unlike what you paid for your combo with free installation), it happens to work great, if Gforce had their axle out first then I would have their axle in. I hardly think that makes me a Hendrix fan.
Either way I'll stay out of your threads from here on out.
Be careful, I got an infraction when I asked the same kind of question to SoJersey.
Thanks for staying out of my threads from now on. I appreciate it and will reciprocate.
Whisler.. Thanks for posting the vid.. Have really been waiting to see something like this.. The results are nice!!!
I have to say, I'm so annoyed that every time I come on this forum and there is a thread about axles, there's nothing but bitching.. I don't get you guys.. We are all here for the same reasons.. To learn more, to share our existing knowledge and make our vehicles better, faster, stronger.. We all have our own opinions, I just think some people need to calm down a little with how they express them...
Again, thanks for the vid.. Will be the next investment
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks for posting this video Wisler, looks like the axles work great and just as designed.
Ok guys, I've explained this before but I'll explain the reason for the different axles and what wheel hop is and why it happens.
Wheel hop happens when the drivers side tire looses traction, once that happens the axle unwinds (The axles are in a constant state of twist under acceleration).
When the drivers side axle unwinds it sends a shock wave or harmonics through the center section and into the passenger side axle. Once this happens the passenger side tire breaks traction and that axle unwinds. It then starts a viscous cycle called "Wheel hop"
To stop this cycle you need (for one) a stiffer axle with different twisting properties then the other axle. The method of obtaining this is to make one larger then the other.
You need a staggered diameter set of axles to most effectively stop the wheel hop, one small and one big.
This method has been proven in the GTO market and also by GM.
The 04-05 V's came from the factory with small axles on both sides.
The 06-07 V's came with big axles on both sides.
Both of these axle designs did nothing to stop wheel hop as you all know.
You have to have a staggered diameter set of axles to most effectively stop the wheel hop.
The 04-05 V's have small axles so you need a big passenger side axle to make a staggered set.
The 06-07 V's have big axles one both sides so you need a small axle on the drivers side to make a staggered set.
The different twisting properties of the axles stop the back and forth harmonics that happen with wheel hop.
Running just one of our axles does a great job of killing the wheel hop.
When you run both of our small and large 300m axles, it works a little differently but still stops the back and forth harmonics but even better.
Our axles are made of 300m and have a really deep heat treat, they don’t twist much at all (but they are still under constant twist under acceleration, just not as much)
so the axles don’t unload much at all when you break traction.
I hope that explains it.
Thanks
Chris @ Gforce Engineering
Thanks
