lifter tick drivers front?
Sure it isn't a exhaust leak? Is it accompanied by a misfire? Could be a coil arcing out or a loose spark plug as well. Also a rocker arm could have come apart. It is about a 10 minute job at the most to pull a valve cover.
But maybe I'm paranoid.
I'll pull a valve cover and check.
I don't, but I did remove the exhaust at the collectors recently to get to my trans mount. That could be a possible point, thank you for the suggestions.
And like said earlier post up some videos and I'm sure it can be better diagnosed.
Here's a vid. Today it got real bad. Still no decrease in power that I can perceive .... Kind of thinking maybe I have a bad plug, wire or coil pack though. No SES lights, but I think I am going to replace them all and see if that helps.
On that note, what's OE for the LS6 ?
CTS-V Shifter Sales
1. Look for evidence of an exhaust leak around the header gaskets. Use good lighting and a mirror. If there is a leak you will see black soot.
2. Replace plugs and listen again.
3. Swap coil packs to the other side of the motor. Listen to see if the noise follows to the passenger side.
4. Seap wires to the other side. Listen to see if it follows.
5. If those fail to change it, pull the valve cover and see if any rocker arms pull off the valve stems. You will have to rotate the crank to put individual lifters on the base circle of the cam to check each one.
