Carbed LS1 diesels when shut off
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I have an LS1 with LS2 heads, hot cam, 770 holly carb. MSD 6LS box and a TCI trans controller. My problem is that it diesels when I shut it off. I had the timing all the way from 6 degrees initial to 22 degrees at idle and it still diesels. There is no carbon build up and the plugs are new. I don't believe also that it is running to lean but not sure... When I fattened up the mixture it seemed to make it worse. Idle is set about 850 rpm's. Any lower then that and it wants to die in gear. Any help why my LS1 diesels or wants to continue to run would be great...
Do you know what compression ratio you end up with? I would double check the idle mixture with a wideband. Keep it as lean as possible.
Back when I was a kid cars use to diesel due to low octane gas. Run a higher octane gas if you aren't already.
The other trick we use to do is leave it in gear when turning it off.
Just noticed Wikipedia has some good info. The last link has some good suggestions.
http://en.wikipedia.org/wiki/Dieseling
http://www.jeepster.org/swchapter/dieseling.html
http://mgaguru.com/mgtech/engine/ro101.htm
It raised the comp ratio going to the LS2 head which is the same chamber as the LS6 head. LS2 head has a 5cc smaller chamber. Not sure how much that raised the comp ratio from the stock 10-1.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I wonder if that hotcam isn't the problem, maybe you want one
with less overlap and better idle vacuum so it doesn't have so
much feeding it, to (barely) run without spark.
But I wouldn't ignore engine cooling either. Sure there is no steam
action? Seeing any coolant puking? Getting an aluminum head hot
enough to diesel seems to take some doing, there are lots more
extreme setups than yours that don't.
Old School Heavy
There is another thread about this LS1Tech somewhere. I remember reading it a couple months ago.
Oh, and one more thing to consider. My head steam vent tube was completely clogged to the point that it had to be drilled out. Fortunately I noticed it when I was painting the item. I would be worth a look to make sure the passage is clear.
That is very low vacuum. I say you have a vacumm leak and the idle is turned up to compensate. With that small of a cam it shouldn't diesal.
Yes, I'm changing to thicker intake gaskets and carb gasket. This is what I narrowed it down to is a vacuum leak. I'll change out the gaskets and will get back with the results...
I have the edelbrock performer carb intake. With LS2 heads. Which raised the comp ratio. Not sure if thats a factor in dieseling. I've tried more timing. That makes the starter kick back, didn't help. I'm sure it's a vacuum leak, cause it doesn't want to idle in gear so I have to turn the idle up a little. I'm sure all my problems are related to a vacuum leak. I have some plugs that are burning leaner that others. That's also a sign of a leak. Hoping this will fix the problem is a gasket change. I'm trying the felpro extra thick gaskets .120 thickness.
If that doesn't fix it. Does it do this no matter how hot or cold it is? Hows the cooling fan's wired? I've seen cooling fans wired incorrectly and cause problems like your having.
Goodluck!
Goodluck!
Never had any over heating issues. Never seen the temp go above 200. And that was at idle in the garage.
Old School Heavy
I know this is a dumb question, but both *speedtigger* and myself had a lapse on this just recently. The Performer RPM has a 10/32 threaded hole on one of the front runners to bolt MSD box on. You would think this would be a blind threaded hole, but it goes through into the runner. If you don't use it to bolt the box on, it needs a 10/32 screw in it. Just a thought, Ron
