got a cam coming for my 370 build.
I have a thread in the drag racing tech section
https://ls1tech.com/forums/showthread.php?t=1500161
Run down
2004 lq4. Block. Stock crank .ls2 rods. Flat tops w/ valve reliefs
.040 headgaskets. 11.25:1 comp.
Ported ls3 heads milled. 035 "
Victor jr l92 intake
Proform 850 carb.
Jp roller timing set
Msd controls the truck coils.
ls7 lifters
Geoff at eps speced me out
235*/251* @050" .621"/.631" 110lsa. Cam has 4* advance built in. Sould peak at 7200
Should he here in a couple of weeks. Can't wait to get this baby running.
Still don't have a l92 Vic jr so if any of you got one for sale pm me.
Thanks.
Run down
Proform 850 carb.
ls7 lifters
Thanks.
When the cam was spec'd, what was Geoff's thought process behind the big 16° split? 235°/251°
That is quite a bit bigger of a split than the ~8° that has become commonplace in the L92 world.
(- Just curious, I am always looking to read and learn about something new.)
What are you planning for headers and exhaust?
What does your camaro weigh?
Mike @ CFM has some produced some great heads.
There is a member on this board running a a nearly identically spec'd engine to yours that has run 10.70's@125 with a 1.47 60ft on pump gas. It is a 6.0 LY6 with CFM ported heads in a 3700lb 68 chevelle, 200r4 trans, Victor jr, 750 carb.
Simple but fast combo.
$$$$$$$ keyword BUDGET LOL
may give pro systems a call once i see how it runs. what carb you running on your lq4
sweet!! i will be tuned in
what setup you got going on
not sure on headers yet. not alot availible for 82-92 camaro.
havent scaled it. has no a/c , heater box, rear seats, crash bars front and rear removed. its an rs maybe 3400 with me in it? im a small guy.
mike was telling me about a guy with a heavy chevelle that he ported up. said it turned out good. thats the results im looking for.
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
he told me the intake valve doesnt need to be open very long to fill the cylinder due to the huge intake ports. we'll see how she runs..
Hawks has some nice headers for the 3rd gen cars. Made by Stainless Works.
http://www.hawksthirdgenparts.com/he...ndgaskets.aspx
pic courtesy of thirdgenbum
![](http://i86.photobucket.com/albums/k108/mw66nova/103_0677.jpg)
Mine is an LY6
.050" cut from the heads
.040" cometic gaskets
Should be ~ 11.0:1
Flycut stock pistons
Cam 236/262 @ .050 110 strait up .6xx/.6xx lift (cam guru did not want me to let that out)
Supposed to peak about 7300, and hang on till 7700 shift point
PAC valvesprings
VicjrL92 850 mighty demon
1 3/4 - 17/8 step Edelbrock headers
Moroso electric water pump
Ati balancer
My car weighs 3425 w/ me, and I'm looking for 10's @ 125 ish........ We'll see
Should be ~ 11.0:1
PAC valvesprings
Ati balancer
Mine is an LY6
Should be ~ 11.0:1
PAC valvesprings
Ati balancer
Should be ~ 11.0:1
PAC valvesprings
Ati balancer
I just remembered I have a quick fuel 1050 up in the attic. I jiust put newa seals it and stored it. Put itit back to the way it came from qft. Do you think that would be a better match to start with? It was in an e85 big block. It had the metering blocks nodded for e85
im doin the same engine pretty much. lq4 with ls2 internals, carb, ls3's, and victor jr. my cam specs are close to yours, 234/250. i hope they run good! good luck with the build i hope your as excited as me to get it finished!
Nope, just ARP2000 rod bolts, no money for rods/pistons right now, next time.
jgillen91 - when do you plan to have yours together? are you going to put it on a dyno? I'm definately interested to see how both our engines do, seems like ALOT of guys putting VERY SIMILAR combo's together.
Barrett
Barrett
In-Zane Moderator
Think hawks offers a 2 inch primary header for 1200, I got my 1 3/4 from them for 800, nice pieces.
Those combos will all run harder than my lq4 with stock heads, I think the 850 carb will be fine, we are not talking 400+ cubes here.
Curious to see how well all you guys run in comparison with the ls3 top ends.
Barrett
Barrett
Couple other choices out there for headers.
BRP:
http://stores.bulldawgmusclecars.com...x-1/Detail.bok
![](http://stores.bulldawgmusclecars.com/media/00/a64735d12eeda4c15db39d_m.jpg)
Hedman Hustler:
http://www.hedmanhusler.com/1982-92-...S-Swap-Headers
BRP:
Hedman Hustler:
