5.3 teardown/build
I just picked up my 5.3 for my ford ranger yesterday. I was getting ready to put it on the stand to tear it down for a rebuild, when i encountered a problem. The 5.3 block is missing a hole, not drilled or tapped. This is normally where i mount my stand on SBC engines.
What holes in the block are you guys using? I already have the bolts, just unsure which holes on the block to use to mount it secure.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I plan on building a 408 later, but i gotta make this thing fit in the Ranger. I'm not sure what year the 5.3 is, came from a shop that pulled it from a wrecked truck, they couldn't remember what year it was, but at $125, i couldn't go wrong. I'm guessing it's an earlier engine, 862 heads and has an EGR valve.
